MR OEM oil drain plug vs non-MR
Old Jun 30, 2008 | 03:26 PM
BGR's Avatar
BGR
Hi guys, do you know if the MR and non-MR oil drain plugs are the same? I know that the MR is 19mm on top, but I am not sure if the thread and size are the same. I want to use JDM magnetic oil plug, but they only offer for "regular" Evos. Any idea? Thanks.
Old Jun 30, 2008 | 03:28 PM
19DB794's Avatar
I think the only diffrence in the MR drain plugs is that it has a sensor attached to it for the oil temp gauge.
Old Jun 30, 2008 | 03:50 PM
Yodobashi's Avatar
Pretty sure the MR drain plug is larger. Believe non-MR uses 17mm.
Old Jun 30, 2008 | 03:54 PM
Jp7's Avatar
Jp7
I just bought an aftermarket oil temp gauge. Can I wire it to the stock sender? Any ideas?
Old Jun 30, 2008 | 04:10 PM
HaVoK23's Avatar
Isn't one of them magnetic and the non........I remember hearing this from someone
Old Jun 30, 2008 | 07:43 PM
andrewzaragoza's Avatar
probably the thread size is the same. if the jdm drain plug doesn't have an oil temp sender with it then you will loose your oil temp gauge.
Old Jun 30, 2008 | 07:56 PM
asilverixmr's Avatar
I just did my oil change on my MR it has a cable attached to it for the oil temperature gauge and the non MR don't.
Old Jun 30, 2008 | 09:00 PM
BGR's Avatar
BGR
I'm aware of the gauge and the sensor attached but I don't think its that accurate to begin with so I rather put magnetic plug instead. Has anyone with an MR done it?
Old Jun 30, 2008 | 09:02 PM
chaotichoax's Avatar
I eliminated the factory gauges in my mr
I just bought a gsr drain plug and voila
iirc the mr drain plug needs a 19mm open ended wrench and the gsr is a 17mm socket or wrench
Old Jun 30, 2008 | 09:16 PM
Nuked's Avatar
yup threads are the same.
SQ
Old Jul 3, 2008 | 09:57 AM
Jp7's Avatar
Jp7
what is the easiest way to install the autometer oil temperature gauge in an MR? I have all autometer gauges, so I am replacing the stock MR Gauges with autometer ones? Should I go to the dealer and buy a drain plug then drill a hole in the plug to install the sender in?
Old Jul 3, 2008 | 11:42 AM
Nuked's Avatar
I believe for an aftermarket oil temp gauge you can attatch the sending unit to the oil filter housing in one of the unused threaded holes. I think there is a how to on here somewhere?
SQ
Old Jul 3, 2008 | 01:05 PM
sk8terdude929's Avatar
Non MR models use a 17mm i think
gklasse
15
Feb 16, 2021 10:14 PM
lst4g63
Feb 23, 2016 12:19 PM
thedru13
10
Oct 17, 2011 05:51 AM
I4UnderPressure
Oct 25, 2010 10:33 AM
lightspeed1
For Sale - Part Outs
33
Apr 16, 2010 11:27 PM
