need some help guys ,,,plzzz
so here it is i had a hks bov in my evo and i did everything correct and one day i decided to give it some gas and the cover tht replaced the stock hole of where the stock bov was at disappeared so i heard this strange whining noise i decided to stick a towel in the hole to let me get home..n i was driving real easy n turns out when i get home that the towel was sucked in into the turbo..and now it makes a weird whinnig noise..=( any ideas???
plz help!!
plz help!!
Holy, crap. You sucked the towel in your turbo...I don't know what to tell you. Wait, that hole is in your intake pipe to your tb not your turbo inlet pipe right? Maybe it's in your intake piping outside your throttle body???
Sounds like your taking some stuff apart tonight.
sounds like it must have been the rubber intake pipe . looks like your turbo is stuffed..
MEaning the first time it sucked something you should have really stopped..
now its a towel too..
I would start with taking that pipe of.
Wow... ... Wow?
That sucks man. Was it tuned to have a blow off valve or did u just add one? You can screw up your engine by not having the car tuned for it because it releases all the air and the next time you step on the gas the car is expecting all that pressure to be built up but gets nothing... then it gets dumped with a BUNCH of fuel and no air.
You're probably going to have to get a new turbo. Might as well upgrade. And make sure if you do a BOV that you have it done right... it can really screw up your car if it isn't.
Take it apart and post pics. Not to sound like a jerk, but I gotta see what this looks like
. When you take you're turbo off, it's best to take it apart to see if it's salvagable and check your intercooler piping as well for fallen debris.
