GT35R to 30R
You cannot really evaluate whether or not you like your current set-up until the current set-up is running at peak efficiency and performance.
Negative issues related to the factory ECU and MAF are highly overrated, IMO.
How much HP before MAF is maxed out
Lots of other threads of high HP cars on stock ECU and MAF.
I suggest a good tune by Mellon and then reevaluate the situation.
Esam, I've not yet found the limits of the stock mas/ecu yet. Currently I'm seeing ~ 500awhp on pump gas @ 30psi with the 35R. I did add c16 recently and at the same AFR and boost but with just 4* more timing the power shot up to ~565awhp before I saw any knock. I never did try raising the boost and lowering timing but I suspect I could pick up more power that way.
I have a buschur stage 3 head on the way to replace the stock head and I have buschur bf272 cams to go in to replace the hks 280's I'm using now. I suspect that I'll be able to make considerably more power at the same boost levels going forward.
there's absolutely no reason to downgrade to a 30R and you shouldn't be getting a CEL regarding the car being too rich or too lean. I'm biased obviously but it sounds like you need a new tuner, someone that's experienced with high hp cars on the stock ecu/mas.
I don't have a dog in this hunt as I'm still with the stock VIII turbo but in my reading, I've never heard of this before. I know this thread is about the MAS but reading through things has caused a few concerns.
It's really a matter of what you're desired needs and ultimate purposes of your car is when choosing the right combination. The stock IX turbo is no joke and it's been proven to be very nice on the road and/or track. I, for one, enjoy autocrossing when events come to town but I spend the majority of my time on the highway. I've looked at the Green and the GT3076R of which both will be ran on meth. But the more and more I look at the HTA35R, the more I think that it's what I'd eventually go with. It won't be as exciting on the autocrossing though.
Chris, I'm the one who converted my son after seeing the EVO/Viper video. Is the Stage 3 head necessary if I wanted to go the HTA35R route? I see that you got rid of the 280's but I don't want to upgrade my springs and retainers. I'd have to do this with the BF 272's, right? Also, what do you think about the HTA35R/meth combination?
With everyone punting the GT35R / HTA35R... I decided to go bigger and opted for the GT3076R over the GT3071R, and boy was I dissapointed with the spoolup. Off and on Boost this Turbo is very soft compared to the Stock IX Turbo. Only reason I went for the GT3076R is because I am in the process of putting in a 2.3L stroker and my goal is 500HP. It's all about spoolup and power under the curve. Doesn't matter if you have to sacrifice 50HP to get this and you won't be sorry. That's what I recomend to my friends that don't want a ringer which is completely maxed out but rather a sleeper with safe mods. After experiancing the GT3076R on the Stock Block 2L with std rev limiter and now that I've thought about it the GT3071R or BB 50Trim is more and more looking like the most appropriate Turbo for the boost levels I want to run 22-25psi and the maximum acceptable lag I would consider 3500-3750rpm.
Esam, I've not yet found the limits of the stock MAS/ECU yet. Currently I'm seeing ~ 500awhp on pump gas @ 30psi with the 35R. I did add C16 recently and at the same AFR and boost but with just 4* more timing the power shot up to ~565awhp before I saw any knock. I have a buschur stage 3 head on the way to replace the stock head and I have buschur bf272 cams to go in to replace the hks 280's I'm using now.
I don't have the stage 3 head or BF 272 cams and springs(required) on yet...it's ~ 500awhp all day long on 93 octane even in this nasty summer heat.
still rocking the stock springs, hks 280 and hta 35R kit
I had an aquamist HSF-5 kit for my HTA 35R kit because I wanted 500awhp and thought I'd need meth to get there...I set the boost to 20psi and it made 400awhp, 26psi and it made 460awhp, 30psi and it made 500awhp.
I promptly sold the meth kit, never installed it haha, why complicate the setup? I put c16 in it once and without raising the boost and using the same AFR it shot up to 565awhp with just 4* of timing.
I'm hoping with the BF 272 cams + Stage 3 head I'll pick up a considerable amount more on pump gas.
I don't have the stage 3 head or BF 272 cams and springs(required) on yet...it's ~ 500awhp all day long on 93 octane even in this nasty summer heat. still rocking the stock springs, hks 280 and hta 35R kit
I had an aquamist HSF-5 kit for my HTA 35R kit because I wanted 500awhp and thought I'd need meth to get there...I set the boost to 20psi and it made 400awhp, 26psi and it made 460awhp, 30psi and it made 500awhp. I promptly sold the meth kit, never installed it haha, why complicate the setup? I put c16 in it once and without raising the boost and using the same AFR it shot up to 565awhp with just 4* of timing. I'm hoping with the BF 272 cams + Stage 3 head I'll pick up a considerable amount more on pump gas.
i have a 35r turbo kit but i was told that it is maxing out my stock maf, my motor is stock and now i must downgrade to a 30R. what turbo will bolt up to the manifold that has the fastest spoolup. for ex. is there a 30r turbo that spools faster than a 3071? ps does anybody have a turbo or turbo kit in arizona they would like to trade for mine? it is almost brand new, 4 mos. pm or email me at esammmorsy@yahoo.com
I'm at 85-90% with twin walbro pumps and 1000cc PTE injectors from Buschur Racing at 500+awhp on 93 octane. When I do the head/cam upgrades it's going to jump up a little more. I see 1200's in my future if I ring it out on race gas when I get the built 2.0 in.
what i ment was that it wouldnt be something that would be done on say an Email flash. I remember in a prior thread a week or so ago that you has said you had taken your personal tune a lil farther than you would normally do a customers.
I like your numbers. I think I may reconsider my current setup possibly.
If a customer of mine had the same setup and wanted to push it to 500 I'd be game.
