The Perfect Turbo-Back Exhaust?
Old Jul 6, 2008 | 12:17 AM
sinpul's Avatar
Just keep it stock! Buy a bigger turbo, cams,injectors,etc,etc. You'll have power & a quite exhaust.
Old Jul 6, 2008 | 01:43 AM
BoostLover99's Avatar
Originally Posted by BluEVOIX
Cobb turbo back or RRE turbo back. Those are the two exhausts that offer exactly what your looking for. I know that the Cobb has an option for a high flow catalytic converter, possibly RRE has one too.
Non of the exhausts will be quieter than stock, but for a full 3" system with no tapers they will be the quietest options out there. With a high flow cat I think you might be close to as quiet as the stock system. With my cobb system and a resonated testpipe, its very cop friendly and quiet enough for daily normal driving to barely hear the exhaust. The exhaust note does rise when WOT but not high enough to wake the world.
Cool - thanks for the tip. I'll check 'em out ASAP.
Old Jul 6, 2008 | 01:53 AM
importjake00's Avatar
Originally Posted by Brad@MellonTuning
the perfect tbe is one that is a true 3" tbe, end of story.
from that, just choose one you like
exactly.
that would be pretty stupid.
Old Jul 7, 2008 | 05:17 AM
wingless's Avatar
I decided to stay 2.5"front to back, prioritizing a smooth consistant path over a wider diameter and inconsistant interior dimension.
2.5" HKS DP (Swain tech coated to keep the heat in and exhaust velocity up).
Random tech high flow 200 cell metal cat (2.5") {the 100 cel flows better, but I have doubts about it passing smog}
Works 2.5" mid pipe without the resonator.
works stealth muffler (stock muffer with one of the baffles removed).
It is a tiny bit louder than stock
It leaves some power on the table
It is compliant with MA legislation
Old Jul 7, 2008 | 05:23 AM
MR Turco's Avatar
I am was running a megan o2+DP -> stock cat+cat back. On the stock turbo i dont see me making too many gains with a catback. The only other power mods i have are a drop in filter and ported exhaust mani. This combination, with 25psi yielded me 290hp/320wtq with boost tapering to 19psi by 7500. Since then i have added the Cobb HFC, which from the butt dyno does feel some better top end but personally i do not see the huge gains/noise from the cat back. I'd rather put $600+ towards head work IMHO and keep the exhaust quiet.
Old Jul 7, 2008 | 09:48 PM
waynea's Avatar
I had generally the same goals and I have been very happy with my Works Stealth setup, even looks stock. Slightly louder than stock, but 3 inch front to back.
Old Jul 7, 2008 | 10:00 PM
hytek369's Avatar
RRE DP with JUN BL CBE
Old Jul 8, 2008 | 09:00 AM
selp's Avatar
agency power titanium muffler
Old Jul 8, 2008 | 09:19 AM
Vivid Racing's Avatar
^^^ The Agency Power DP and CBE are true 3 in exhaust. Sounds and looks are very nice as well! We have them here in stock.
Evan Smith
