Indy Intake Manifold power bands and availability.
Old Jul 13, 2008 | 02:11 PM
  #76
Indy Evo's Avatar
scheides we should have a pretty good idea this week when AWD Mike and Buschur runs theirs on bolt on type cars. Thanks
Old Jul 13, 2008 | 06:59 PM
  #77
Indy Evo's Avatar
03 thanks again for posting the numbers. Apples to apples, against Buschur's stock ported intake with a stock TB: v1 +49whp/+46ft/lbs. v2 +54whp/+43ft/lbs. corrected to the stock intake run in Feb. I believe these runs were done with less boost than the other manifolds run in his magazine test. v0 numbers this week. Thanks, Indy
Old Jul 13, 2008 | 07:45 PM
  #78
Warrtalon's Avatar
It's difficult to determine what to do here. IX turbo on E-85 on a car that is built for road racing and autocross, so I'm more concerned with spool and mid-range than top-end. I also lose power dramatically above 5500rpm due to altitude, so I shift at 6300-6400. I was considering porting the stock IM/TB, but I haven't seen a graph of those specific mods vs stock nor the V0 vs stock or ported. Then, I have to decide which combo would mate with the Green in the same scenario...hmm.
Old Jul 13, 2008 | 08:51 PM
  #79
scheides's Avatar
EvoM Moderator
Warr, I say go green and v0 and be done with it. It's most likely going to be the best combo for top end power and quick spool down low. I think that any of these manifolds on a maxed out stock IX turbo are going to die off after 6500, the turbo is just out of gas up there.
Old Jul 14, 2008 | 10:21 AM
  #80
Indy Evo's Avatar
scheides you might want to talk with 9sec9 since he ran the White pretty hard upstairs.
Old Jul 14, 2008 | 10:38 AM
  #81
David Buschur's Avatar
Altitude, temps, humidity..........all play a roll in hp/ET's. I personally do not feel that they play as big an effect on a turbo charged car as they do on a naturally aspirated car.
I've told this story before. I'll tell it, briefly, again.
Early 2000's we were at Bandimere racing, 5800 ft. The best my car had ever run was a 7.9X.
We got there and the car wouldn't start. We pulled the head, found that my dumb *** had put the pistons in backwards and all the intake valves hit, bending them. A local guy ran and got me a new head gasket. I had no ring compressor so we gently pushed one piston to the top at a time, moved the crank around and spun the pistons in the bore so they were positioned correctly. Put the car back together, still wouldn't start. Compression was under 90 psi in each cylinder. We hit it with some starting fluid and it fired. I then held the engine on the rev limiter on and off for fairly long periods to try to get the valves hot enough to slam them against the seats and straighten them out. We finally got it so it would atleast start on it's own.
The car ran either an 8.1 or 8.2 there with the engine in that shape. So at most .2off from it's absolute best ever.
IF the car is tuned for altitude and turbo charged I don't think altitude will hurt the ET by much, if any.
Old Jul 14, 2008 | 10:43 AM
  #82
Aby@MIL.SPEC's Avatar
Originally Posted by Aby@MIL.SPEC
Was a oem tb used for all manifolds tested on the graph for post 1 or was it oem tb /oem IM vs Buschur 65mm tb / V1&2?
Old Jul 14, 2008 | 10:46 AM
  #83
Indy Evo's Avatar
Sorry Aby
Old Jul 14, 2008 | 10:47 AM
  #84
Warrtalon's Avatar
It has about half the effect on turbo'd cars as it does N/A, but it's still a large effect. The larger and more efficient the turbo, the less it seems to matter, but when you're already at the limits of efficiency at sea level, then you have no way to compensate at altitude. The standard CF for SAE up here is usually in the 1.25-1.30 range as calculated by the weather station. This seems to be just right for N/As, but we cut that in half for turbo'd cars when trying to estimate sea level numbers. I just use uncorrected, but it's all just numbers.
Fact is I lost 40whp peak and closer to 50whp at 7k rpm when moving from VA to CO. Even with a retune and trying to raise the boost, I got no closer except for a little bit before 5300rpm:
Green line is at sea level just before moving. All the other lines are at altitude right after moving. Each line is a different boost/tune level - I kept going up until it was maxed. You can see the highest curve, which is around 28psi MAP. It gives me peak torque closer to the sea level one at 26psi, but notice how it falls right back inline with every other pull at around 5500rpm.
Huge loss in spool, big loss in peak whp, and huge loss in top-end as you can see the curves diverging as RPMs increase.
  #85
The baseline was stock intake/stock throttle body.
All testing after that initial intake manifold test was done using OUR 65 mm stock throttle body.
Old Jul 14, 2008 | 11:37 AM
  #86
03whitegsr's Avatar
When it comes to correction factors, I try to avoid comparing sea level cars to altitude cars and I'll leave it at that with regards to altitude.
Correction factors are for comparing one run to another on the same car on the same dyno. Exactly what this thread is about.
Old Jul 14, 2008 | 12:16 PM
  #87
scheides's Avatar
EvoM Moderator
Yea, but White != OEM IX turbo
Old Jul 18, 2008 | 11:01 AM
  #88
Indy Evo's Avatar
The first two v0's are on the way to Buschur's for testing. They should be delivered on Tuesday in time for a dyno and on track testing by Trent-o-matic. AWD will get a v0, and v2 custom w/ 3" Wilson TB next week, stand by for more dyno and on track testing next week. 9sec9, and OKIX will be running at tonight at Tulsa for the first shakedown runs since the new build. Good Luck guys, Indy
Old Jul 18, 2008 | 11:27 AM
  #89
psphinx81's Avatar
id like to see how this compares to "magnus's" new manifold that was just released.
my $$ is on indys v2 manifold
Old Jul 18, 2008 | 11:29 AM
  #90
Billy@EnglishRacing's Avatar
Are there pics up of these manifolds?
