Car suddenly will not build boost at a stop
Car still builds boost fine otherwise and holds it very well to redline, but from a stop, it will not build any boost anymore. Any ideas?
Thanks in advance
Thanks in advance
I am holding it long enough to build boost. I haven't done a boost leak test yet but I would think I would see a bad taper at redline if that was the case. It holds strong at 23 lbs.
Who is the current tuner of your car? When is the last time you can remember boosting on the two-step?
watching a boost gauge won't guarantee you don't have a boost leak. The turbo will simply overspin to compensate, whereas during the 2-step the turbo will not.
It's just a hunch...because it doesn't make sense if the tune wasn't changed and the turbo doesn't seem to be damaged.
I will check for a boost leak. I currently tune my car myself. Honestly it has probably been a month or so since I last tried and everything worked fine. Since then I have made no modifications.
I have launched my car many times as well as do all my own modifications and my own tune. I can tell when something isn't right. I don't mean that as an insult. Mixing a couple gallons of 110 with 93 wouldn't cause this would it?
