No Boost After Install!
Old Jul 13, 2008 | 07:35 PM
EVOIXreno's Avatar
Ok i just installed my O2 housing downpipe test pipe and Forge MBC... I am wondering why I have no Boost..I took the header off for the O2 install and I put everything back on and I hear a loud ticking noise!
Old Jul 13, 2008 | 07:39 PM
06ravenmr's Avatar
the ticking noise could be u just hearing ur lifters or injectors. if u dont have an exaust leak then check the mbc how did u hook it up
Old Jul 13, 2008 | 07:43 PM
EVOIXreno's Avatar
One from the wastegate to mbc and the other from turbo to mbc...I have switched them and still nothing..I get 0psi on my guage and my car feels like crap...where could the exhaust leak be coming from if i had one?
Old Jul 13, 2008 | 07:45 PM
06ravenmr's Avatar
it could be anywhere from the header to the 02 housing. i really couldnt tell you without looking. tee off of ur bov instead of going to the turbo. holds boost better and less spike
Old Jul 13, 2008 | 08:01 PM
sparky's Avatar
Originally Posted by EVOIXreno
Ok i just installed my O2 housing downpipe test pipe and Forge MBC... I am wondering why I have no Boost..I took the header off for the O2 install....
Why did you have to R&R the header for an O2 housing install?
Old Jul 13, 2008 | 08:15 PM
Jon91TSi's Avatar
Do you have the turnbuckle on the WG flapper? Even with a massive exhaust leak at the header or o2 youd still see some boost.
Old Jul 13, 2008 | 08:21 PM
06ravenmr's Avatar
u dont have to touch ur wastegate so its def something he did. but still theres no way to get 0 psi. i had to remove my whole turbo to do my 02 but thats becouse i have the invidia. he probably took it off to make it easier.
Old Jul 13, 2008 | 08:23 PM
sparky's Avatar
A leak between the header and the cylinderhead would hurt spool. Also, a leak at the flange between the turbine housing inlet and the header would effect spool. But a leak between the turbine housing outlet and the O2 housing, being post- turbo, would not impact spool to the same extent that a pre-turbo leak would.
Old Jul 13, 2008 | 09:04 PM
EVOIXreno's Avatar
ok so I found out that on the Stock BCS I should have left the line that goes to the intake...would that cause 0psi if it isn't capped?
Old Jul 14, 2008 | 07:54 AM
eponti's Avatar
You should see at least a wastegate psi of 15.Double check your MBC.
Old Jul 14, 2008 | 09:18 AM
EVOIXreno's Avatar
I think the waste gate is stuck open!
Old Jul 14, 2008 | 03:07 PM
EVOIXreno's Avatar
Fixed... O2 housing wasn't keeping the waste gate shut Installed it wrong I guess!
Old Jul 14, 2008 | 04:41 PM
06ravenmr's Avatar
good to hear
Old Jul 14, 2008 | 04:45 PM
importjake00's Avatar
Glad you got it fixed!
Old Jul 14, 2008 | 10:19 PM
eponti's Avatar
Glad it's an easy fix.
