Problems shifting from 3rd to 4th?
Old Jul 17, 2008 | 05:46 AM
WRCBred's Avatar
I've been having issues with the 3-4 shift when shifting close to redline. I have an ACT HD Clutch and flywheel. Is there a known issue with this setup on the 3-4 shift, or am I just goofing up the shift. I powershifted 3-4 at the track and had no problems, but since then I've missed like 3 or 4 shifts on the street.
Old Jul 17, 2008 | 09:00 AM
Evo8luva's Avatar
I had the same problem, same clutch, the clutch disk hub was rubbing on the pressure plate causing it to never fully release. sometimes I would miss 2nd but always miss 4th and if I was high rpm shifting into 5th same thing. Destroyed my trans, had to get 2-5 gears replaced all syncros and collars.
Old Jul 17, 2008 | 09:03 AM
EVOlution561's Avatar
I had the act 6 puck, I had similiar problems so I adjusted the clutch pedal all the way up and it was shfting pretty good after that. You can try that, it won't hurt. If you don't know how to, there is a really good how-to on EVOMOTO.COM
Old Jul 17, 2008 | 10:41 AM
jmartinez1170's Avatar
Yep they lockout out highrpm shifts its a common problem.
Old Jul 17, 2008 | 01:33 PM
Evo8luva's Avatar
Prolly worked for you because you have a different disk, then him or myself.
Adjusting mine did not fix my problem. In my case part of the clutch disk that was never supposed to touch any part of the pressure plate or flywheel was rubbing against the press plate fingers. Not cool.
Old Jul 17, 2008 | 05:03 PM
EVIL MR's Avatar
Same crap here. way to go usa.
Old Jul 19, 2008 | 12:34 PM
EvoInvidia's Avatar
same thing with me, i just upgraded to the exedy twin. no more act for me.
Old Jul 19, 2008 | 07:00 PM
huevosrancheros's Avatar
So you guys are saying that ACT is garbage as long as it concerns it application for the EVO????
I was thinking of upgrading to an ACT street clutch.
LMK your thoughts and conerns.
Old Jul 19, 2008 | 08:03 PM
chaotichoax's Avatar
I had 3-4 lockout at high rpm sometimes and I remedied this completely with buschur underhood shifter bushing
make sure your clutch rod is adjusted properly
the act hdss clutch is not junk
Old Jul 19, 2008 | 08:37 PM
Evo8luva's Avatar
My trans disagrees.
It seems that act hdss is hit or miss, a lot of evo owners have had issues with this clutch, myself with my evo, and my subaru.
Old Jul 20, 2008 | 08:16 AM
cgwalushka's Avatar
i have to say i've had the same problem act clutch i deystroyed my trans do to lock out! i now have a shep five speed and seem to do the same thing i adjusted the rod a lot better! saving for exeddy twin disc!
