HELP!!! EVO Stalling out then locking up while driving
My evo has a problem... it starts to stall out then the steering locks up while im driving and its really hard to turn. From what I see before it happens my rpms drop and all the dash lights light up. Sometimes i can avoid it by pressing the gas pedal to keep the rpms from dropping to much. It happens alot when im dropping down a gear and turning. My friend said it could be the timing but im not sure.
My mods are:
Cosworth M2 272's
Supertech valve springs
ARP headstuds
GM Boost Solenoid
Walbro 255
AEM Short RAM
TBE
My mods are:
Cosworth M2 272's
ARP headstuds
GM Boost Solenoid
Walbro 255
AEM Short RAM
TBE
I dont think its thats. I think it might have to do with the cam timing or something because the rpms drop then i starts to stall out so it loses power and thats when the steering wheel gets hard to turn because its power steering -_-
well check the timing, put the crank pully at TDC with a 22mm socket or 1/2 drive (its marked), take the plastic cam gear cover off and check the timing marks on the cam gears, they should line up with 2 notches on the valve cover. if you don't want to do that, I would not drive the car anymore, take it to a shop that knows what they are doing.
Are you tuned for your cams and other stuff?
Yes I was tuned, I think I will call them on monday for a retune
