Clutch Master cylinder or just cylinder
Old Jul 5, 2008 | 03:13 PM
joyce1bro's Avatar
ok so my clutch is not bleeding up or well it does and then goes soft. dosent seem to get the pressure needed to operate the clutch properly...
can anyone tell me how i can eliminate one or the other easily so i dont have to pull them both off?? i cant see any leaks...
Old Jul 5, 2008 | 03:28 PM
dieselmd's Avatar
My clutch pedal moves to the floor during agressive shifts. After speaking with a few experts it was concluded to be an hydraulic issue. I'll be installing a new master cylinder. Pm me and I'll let u know how it turns out.
Old Jul 6, 2008 | 12:33 AM
joyce1bro's Avatar
well my clutch did start to get shorter and shorter and then it blew. i then get a new clutch (4 puk solid with 3200lbs of clamp) and when i tried to bleed it dosent want to fully disengage... i might just pull both the cylinders off and get them tested...
Old Jul 20, 2008 | 02:06 PM
06MRV8Killer's Avatar
Might be the slave cylinder... Mine was shot after 28K on mine just replaced it and everything is all good.
Jokiesmurf
17
Jul 23, 2012 07:37 AM
fafaforza
Mar 19, 2012 09:03 PM
chrisff521
Aug 12, 2011 08:47 AM
jk68x3
Oct 20, 2009 08:01 PM
