Evo clutch master cylinder line
Old Aug 9, 2011 | 08:12 AM
chrisff521's Avatar
What is the clutch master cylinder line that threads into the master cylinder called? And is there any local auto parts store I can get it from. Autozone did not have any clutch lines for the evo.
OR I was thinkin I could use a barbed fitting with a rubber hose clamped up tightly. If so what size fitting do I get.
Old Aug 9, 2011 | 03:15 PM
barneyb's Avatar
Factory part only. And, forget about the using a hose - too much pressure.
Old Aug 9, 2011 | 03:19 PM
Bobster22388's Avatar
Either get the line from the factory already pre-bent, or just go buy some 3/16" brake line and bend it yourself. Its really easy stuff to work with.
Old Aug 9, 2011 | 05:50 PM
tmaddox's Avatar
use a tubing bender if you bend it yourself, you don't want to kink it or restrict it
Old Aug 10, 2011 | 09:28 AM
chrisff521's Avatar
The fitting is 3/16" then?
Old Aug 10, 2011 | 09:58 AM
chrisff521's Avatar
I cant even find it online at oemmitsuparts.com
Old Aug 11, 2011 | 08:54 PM
The line size is 3/16". The fitting is a 3/8"-24 on both ends of the line if I remember right. Also with 3/16" a tubing bender is not necessary unless making some really elaborate bends, anything less than 90* and you should be fine. The coated brake line is even easier to bend.
Old Aug 12, 2011 | 08:47 AM
chrisff521's Avatar
Thank you that answers my questions.
David Buschur
Dec 26, 2018 10:40 AM
MisUnderStood
48
Oct 3, 2017 07:57 AM
BlowMeOff
Sep 28, 2012 11:55 AM
KlanjacOFF
10
May 29, 2011 04:19 PM
pyrofire127
Sep 5, 2010 01:29 PM
