HELP! Clutch master cylinder question...
Old Sep 27, 2012 | 05:26 PM
BlowMeOff's Avatar
Question HELP! Clutch master cylinder question...
Ok I'm installing a new clutch master and slave cylinder in my car and ran into something I thought was odd and was wondering if someone here could tell me if it's normal or not. When I pulled off the line that goes from brake master cylinder reservoir to the clutch master cylinder I was expecting brake fluid to pour out (my brake master is near the full mark) and nothing came out at all...not even a drop. Is this normal? I thought that the fluid would've poured out to keep the clutch master cylinder "full". Thanks for any input.
Old Sep 27, 2012 | 06:04 PM
Adio's Avatar
Not 100% sure on how the master cylinder operates but is there any possibility you could have a blockage or build up in the hard line?
Old Sep 27, 2012 | 06:44 PM
BlowMeOff's Avatar
Well I'm replacing the hardline with a STM full stainless braided line, was just wondering why the brake master isn't letting any fluid out it's reservoir, I guess I'll find out if it's normal or not after I try bleeding the system.
Old Sep 27, 2012 | 06:46 PM
Adio's Avatar
Well good luck with it let us know what you find out.
Old Sep 27, 2012 | 07:22 PM
lostsoulsevo's Avatar
yes its normal! just changed mine and my clutch line with the stm master to slave line. just make sure your brake master is full of fluid when bleeding the clutch.
Old Sep 27, 2012 | 07:26 PM
BlowMeOff's Avatar
Will do
Thanks buddy!
Old Sep 27, 2012 | 10:14 PM
masonh's Avatar
i just did my STM line as well,but i left the master hose on,so i can't say.i will say that if you have big hands like i do,it's a ***** to get the new line on the clutch master.i ended up putting a drop of CA on the copper crush washer on the outside to hold everything together while i fished it back in there.
also if you are using a Quartermaster clutch you will need a -3an flared union fitting (jegs or summit) for the TOB/Clutch master line connection.the QM kit comes with a fitting for a banjo bolt.
Old Sep 28, 2012 | 10:58 AM
BlowMeOff's Avatar
You aren't kidding about the fitting to the master, was a complete PITA!
Old Sep 28, 2012 | 11:55 AM
i took the master cylinder out with the lines attached, made it much easier!!!
kyoo
Jan 25, 2020 04:37 AM
MisUnderStood
48
Oct 3, 2017 07:57 AM
hiboost2.0
Mar 23, 2016 05:38 PM
KlanjacOFF
10
May 29, 2011 04:19 PM
MyRoN
04-06 Lancer Ralliart How To Requests / Questions / Tips
Dec 23, 2006 06:23 PM
