Is this too much for main bearing oil clearance?
Old Aug 22, 2012 | 02:08 AM
My03evo's Avatar
Arrow Is this too much for main bearing oil clearance?
I'm in the process of starting to assembly my shortblock...as far as mains with the .0001 bigger bearings I have like 3 thousandths main oil clearance (checked with tools not plastigauge). Engine is fully forged/ported head/fp black/meth/etc running over 35+ psi and around 600+ hp range....Will be running 15w40 or 20w50 oil. Should I stick with this oil clearance or get the stock size bearings and run 2 thousandths clearance?
Haven't checked rods yet
Thanks
Old Aug 22, 2012 | 08:02 AM
THUB's Avatar
.003 on the mains is pretty big. I shoot for about .002-.0023 for my builds. OEM spec is .0012-.002.
Old Aug 22, 2012 | 08:06 AM
okevolutionVIII's Avatar
Do what you can to get it to the .002-.0024 range then run 20w-50.
Old Aug 22, 2012 | 05:33 PM
MRfabolous's Avatar
What should he oil clearances be on Maine and Rods on a 800+ 9000rpm + motor
Old Aug 22, 2012 | 06:23 PM
JohnBradley's Avatar
.003 is not too large. Lots of factors on the mains...RPM, stroke, oil used, reciprocating weight. You'd be surprised at some of the clearances in race motors
Old Aug 22, 2012 | 06:55 PM
n2oiroc's Avatar
the "service limit" is .009". while i wouldnt recommend it, loose mains arent the end of the world. .003" isnt bad.
Old Aug 23, 2012 | 09:09 AM
Aby@MIL.SPEC's Avatar
.003 is fine for a engine making 600whp.
a general rule of thumb is .001 clearnace for every 1.000" in diameter.
Since the mains are ~2.2xx, a .0022 clearance is fine.
Since your going to make big power, you'll probably run a heavier oil, ~20w50, so a .003" clearance will be well suited for a thicker oil.
Old Sep 28, 2012 | 01:14 PM
My03evo's Avatar
Thanks..I can see mains can handle more clearance but what about the rods? Since it has pushing and pulling on it constantly it would be better to have less clearance right? Since all the mains do is basically spin in a circle
Old Sep 28, 2012 | 01:20 PM
n2oiroc's Avatar
rods should be between .002" and .0025".
Old Sep 28, 2012 | 05:07 PM
Pirana's Avatar
Woo, good info here!
Old Sep 28, 2012 | 06:34 PM
1d10t's Avatar
+1
It's been a while since we had such good info
babaz7
34
Oct 13, 2017 04:57 PM
Ef8b16
50
May 8, 2017 08:56 AM
dkutej
Dec 5, 2015 07:55 AM
Steven
115
Dec 3, 2014 12:39 PM
My03evo
17
Oct 10, 2012 12:14 AM
