Bleeding the Master Cylinder
Hey guys, i got a new clutch slave cylinder and last night i had a bit of problems.
i would have to push on my clutch pedal a few times for it to build pressure, then a few minutes later, it will loose pressure and have to push on it again for it to tension Up. Now i'm lost of ideas, becasue it does build pressure but then looses it again.
I did bleed the clutch and did everything i was told to. I think the master cylinder might need bleeding as well.
Let me know what your ideas Are.
Also, when i open the bleede nipple on the Slave cylinder and pour fluid in the reservoir, it bubbles. (gravity bleeding) dunno if that helps, but let me know what you guys think
Cheers
Cheers
BLEEDING M1351001400284
CAUTION
Use only brake fluid DOT 3 or DOT 4. Never mix the speci-
fied brake fluid with other fluid as it will influence the brak-
ing performance significantly.
MASTER CYLINDER BLEEDING
The master cylinder used has no check valve, so if bleeding is
carried out by the following procedure, bleeding of air from the
brake pipeline will become easier. (When brake fluid is not con-
tained in the master cylinder.)
1. Fill the reserve tank with brake fluid.
2. Keep the brake pedal depressed.
3. Have another person cover the master cylinder outlet with a
finger.
4. With the outlet still closed, release the brake pedal.
5. Repeat steps 2 − 4 three or four times to fill the inside of the
master cylinder with brake fluid.
CAUTION
finger.
OKay guys...this is the problem...WHen u push my clutch in ...and i'm in first gear..My car still rolls forward...so this means waht? either the TO bearing is not releaseing the full clutch, or what else...I dont want to drive my car like this, coz its the only car i have..dont want to screw things up....Any help or ideas on this issue...Sorry i'm just full of problems with this car....cant trade it in coz i'm upside down
thanks for all u guys help...really appreciated.
Myron
Myron
TeamEmperor-
Jan 31, 2017 09:02 PM
MRivera78
May 30, 2016 12:44 AM
vaflyboi757
Dec 18, 2015 10:27 AM
KlanjacOFF
10
May 29, 2011 04:19 PM
