HTA 35 to HTA 37
Old Jul 20, 2008 | 11:46 PM
dragers's Avatar
HTA 35 to HTA 37
Hi, I have a HTA35 turbo and it works great, but I drag race allot and would like to upgrade it to the HTA37 does someone know how many rpms more to begin working would it be with the HTA88 or Gt37? Right know is 4400rpm with the hta35.
Old Jul 21, 2008 | 02:34 AM
JC evo1's Avatar
Do you run 9's? If not i would stay with the 35 and look at the rest of your setup first before touching the turbo.
Old Jul 21, 2008 | 05:53 AM
SloRice's Avatar
^^agreed. I'm running a HTA35R and run the times in my signature.
Old Jul 21, 2008 | 06:55 AM
vwjeff's Avatar
JC is right. It wouldnt be worth the extra $
Old Jul 21, 2008 | 09:00 AM
Migsubishi's Avatar
+1 I'm with these guys!!!
Old Jul 21, 2008 | 10:51 AM
dragers's Avatar
thanks for the response, I run hi 10s, we run in hot climate. My car is full weight.
I have the buschur setup too.
someone knows spool up rpm in the T4Z 88HTA?
Old Jul 21, 2008 | 11:19 AM
Migsubishi's Avatar
600-1000rpm laggier than what you have now! Not worth the trade off, read sig! If you feel you need more, your not boosting high enough, if you are over 42psi then turn it down a little and throw a 50 shot on it!
Old Jul 21, 2008 | 02:18 PM
dragers's Avatar
Im boosting 35 psi
Old Jul 21, 2008 | 04:56 PM
SloRice's Avatar
You run high 10's on pump gas or race gas?
Old Jul 21, 2008 | 05:16 PM
vwjeff's Avatar
According to DB spool is 200 to 300 rpm later on the HTA 37r than the HTA 35r.
Old Jul 21, 2008 | 11:48 PM
haseeb's Avatar
now ive got the same questiong butttttt i wana upgrade my standerd gt35r turbo to hta gt37r ...wat do u guyz say ... is it worth from normal gt35r to hta gt37r ?
im on 2.3l and will be running 35 psi boost .
thanx
Old Jul 22, 2008 | 09:01 AM
TwStDeVo's Avatar
if this is fact, then the hta37 is alot better than what people think. do you think it would be a better option than the hta35r if im running pump and alky and 32-35lbs of boost?
Old Jul 22, 2008 | 10:05 AM
Migsubishi's Avatar
Buschur is a super tuner, we don;t all have his parts nor his skills and yrs of knowledge. We cant go by what his car does... He is also running 9.4 on one too which is not achievable by just anyone. It would make sense that the spool characteristics would be the difference between a normal 35r and 37r, now if you make them both HTA's I don't see the HTA 37R all of a suddon closing a 3-600 rpm gap.
You guys do what you want, I'm running a 10.1:1 comp 2.4l with T4 HTA 35R and 100 shot
Old Jul 22, 2008 | 08:22 PM
dragers's Avatar
vp NO2 , I havent tried without it ,
I sold my evo8 to a friend and want to build a newer one with the same setup only changing to the 88HTA, I love drag racing and do that allot. thanks for the advise 200 to 300 rpm increase in spool up seems fine.
Old Jul 22, 2008 | 08:54 PM
Migsubishi's Avatar
^ I think your making a mistake, I would do some more reading if I were you. It seems that you are set on switching from the HTA 35R so I honestly believe the best turbo for you is the 850R. It gives you standard 35R type spool and makes more power than the HTA88 aka HTA 37R
Read
https://www.evolutionm.net/forums/sh...highlight=850r
https://www.evolutionm.net/forums/sh...&postcount=192
https://www.evolutionm.net/forums/sh...&postcount=187
This would be the only turbo I would step up to, if I ditched the HTA 35R period!
