A little of this, a little of that....500+ pump again
Old Jul 21, 2008 | 11:52 AM
David Buschur's Avatar
John Brewer came in today from the great state of Tennessee for a re-tune after changing some parts on his car.
The last time he was in he had 1,000 cc injectors a standard AMS turbo kit with a normal GT35r and 5 bolt .63 a/r turbine housing, HKS cams on the car.
The car on 93 octane made 416 whp and 362 ft lbs.
The car on 110 octane made 528 whp with 479 ft lbs.
The car has a self built 2.3 liter engine in it
BR Race FMIC
HKS Twin power
AMS header/02 housing/downpipe
JDM style catback (not sure what brand it was)
AMS VSR intake
BR Stage 3 head
AEM EMS
The changes to the car since the last time he was here were the following:
BR 272 cams
HTA35R with the same 5 bolt .63 a/r turbine housing
Full Blown double pumper
5 bar map sensor
1200 cc injectors
BR dual stage boost controller
I tuned the car on 93 octane first. I started having problems with the car after having the car very close to being dialed in. The car was misfiring and would not rev. I thought at first it was a fuel pressure line blown off, a quick check of that showed that was fine. I then checked the fuel gauge and it showed the car had about 3/8th of a tank of fuel. As I was talking to John about the problem the car was having it quit running. It ran out of gas..........very odd. My conclusion is either the fuel pumps were not all the way down to the bottom of the tank or there was a problem with the float/sending unit. John is going to look into the problem later, more than likely a simple installation error.
Once we added some more gas the final pump gas pull was made and the put down 508 whp and 417 ft lbs of torque at 30 psi. Very impressive gain of 92 whp and 55 ft lbs of torque over the last time it was tuned here.
I did a race gas tune next and ran it as high as 38 psi. The top end power with the .63 housing and 35r wheel on a stroker didn't shine as nicely as the pump gas but still managed to make 557 whp and 486 ft lbs of torque. A 29 whp gain and 7 ft lb increase.
We then put up a few dyno charts against his for comparison and the low end power of the car is rediculous compared to some others we layed over it. It was a very interesting comparison actually. Power under the curve was just excellent on this car but sacrificed some uptop.
Here are the dyno sheets of the car now. Pump gas is run #1 and race gas was run #2.
Old Jul 21, 2008 | 11:55 AM
leecavturbo's Avatar
Bushur skills
Old Jul 21, 2008 | 11:57 AM
lexat20's Avatar
That must be really annoying to make all these 500+ hp cars every damn day.
I recently put on a 3065 kit of yours and couldn't be happier. Keep up the great work.
This car is on an AEM EMS?
2highpsi's Avatar
So you just pushed out 2 500+hp beasts before 3pm.
I would say it was a successful day. Go have a well earned beer
Old Jul 21, 2008 | 11:58 AM
Yes, AEM EMS on this car too.
Unfortunately, I didn't put two 500+ whp cars today......Babur's was on Friday
BTW, no names were left out and no stickers were removed.
Old Jul 21, 2008 | 12:02 PM
4kinboost's Avatar
Old Jul 21, 2008 | 12:20 PM
8thWonder's Avatar
I'm glad you silenced the nay-sayers with a build not entirely from your shop! Funny stuff.
Old Jul 21, 2008 | 12:22 PM
do you think you'll be putting more and more 500bhp motors out the door
running std management?
Old Jul 21, 2008 | 12:27 PM
StevenStarke's Avatar
ok your really starting to get crazy with these threads every single week, 500whp+ mustang dyno #'s ALL THE TIME
Old Jul 21, 2008 | 01:07 PM
leecavturbo, what do you mean with standard management? Do you mean on the stock ECU? If so, no, I don't see me ever doing that. This car had an AEM EMS on it.
Old Jul 21, 2008 | 01:26 PM
Shacochis06's Avatar
do you think a build like this would be capable of numbers right around 500 on a stock ecu on pump?
Old Jul 21, 2008 | 02:04 PM
dafunk630's Avatar
damn Buschur is on a roll with all the car comin out from there!!!
Old Jul 21, 2008 | 08:08 PM
No I cannot make 500 hp on pump gas on the stock ECU with this same combination, no way.
Old Jul 21, 2008 | 08:30 PM
red03evo's Avatar
Good numbers as usual. Keep up the good work DB!
Old Jul 21, 2008 | 08:51 PM
jmelocik's Avatar
Don't cut yourself short David, I am sure with all the stuff you guys are putting out of your amazing shop that a 500whp stock ECU car isn't to far in the future with a similar build to this! Maybe we should try on my car! LOL
Josh
