Your thoughts about this combo on cams....
I know there is probably a thread out there about cams shaft but I just need to get quick answer. I made a bid on eBay for an HKS cam gear and 264/272 (intake/exhaust) cam shaft. Is that a good combo?
Depends on what you call worst. The had the best idle and where only slightly down on horse power. I have the 272/272 combo, I can't understand why you would want to go 264/272. I personally like the cams alot and if you buy cam gears you can adjust your power band anyway.
Well, I was thinking of 272/272 but it was a combo that has 2 cams and 2 camshaft. I made a bid for $500 and I'm currently the high bidder so it depends if I win or not. I suppose if I didn't win, that'll be great so I can get the 272/272 combo in the near future. But if I do get it, I'm sure it'll at least run better than stock.
Crap
Lets hope somebody outbids me
If not, I'll have to get a 272 intake cam shaft. I don't plan on doing it until I hit 60K miles so I can do the T-belt, balance belt and water pump at the same time.
