Best Cam Gears On an 8 ....???
Old Jul 21, 2008 | 10:13 PM
PedroMartinez's Avatar
Hey guys . I was wondering what are the best cam gears to purchase for an evo 8. Or does it really matter as much as cams? I have searched but really cannot find the answer i want. I have Tomei Pro 280 cams and would like a Nice set of Cam Gears that match my good cams . Also have an AMS 35r kit.
So the question is simple . what are the best Cam gears I could buy ?
Old Jul 22, 2008 | 08:01 AM
Ludikraut's Avatar
Personally i would probably go with either the Fidanza or AEM cam gears - both are a 5 bolt/spoke design, which I would prefer over the HKS 3 bolt design. I currently run a pair of the original Vishnu cam gears (also a 5 bolt design).
l8r)
Old Jul 22, 2008 | 08:05 AM
ApacheFixer's Avatar
they;re already on the car
Old Jul 22, 2008 | 08:06 AM
evo/lightning's Avatar
Hey Ludikraut, what kind if degrees do you have your cam gears set up.
Old Jul 22, 2008 | 08:39 AM
Zeus's Avatar
Unless he's doing a serious build which requires needed adjustment, you are absolutely correct. No need to add another possible failure point on a daily driver for minimal returns. MANY of the fastest and quickest cars in the States are running OE gears...
Old Jul 22, 2008 | 09:05 AM
Ev0cRaZy's Avatar
For your setup, Stock ones should be just fine.
Old Jul 22, 2008 | 09:36 AM
Ludikraut's Avatar
I run HKS 280 cams set to +2 intake, 0 exhaust. I used to run HKS 272 cams set to -4i/-1e.
l8r)
Old Jul 22, 2008 | 09:39 AM
AEvo2Nv's Avatar
Fidanza cam gears bro.
Old Jul 22, 2008 | 10:04 AM
dsmdeliveryboy's Avatar
Ya I was wondering the same thing, I have HKS 272's but everyone say's to just keep em stock...
Old Jul 22, 2008 | 10:40 AM
Ludikraut's Avatar
It's definitely not 'everyone', since I do recommend and use cam gears.
l8r)
Old Jul 22, 2008 | 11:26 AM
l8r)
Thats what I have on my evo 8 at this time 272 HKS cams and hks cam gears, I just have the gears at zero for now. So what was the performance results from you having HKS 272 cams set to -4i/-1e? thanks.
Old Jul 22, 2008 | 11:33 AM
YzBrad99's Avatar
Keep em stock, youll be fine. I got stock gear with Cosworth M2's and no need to adjust em.
Old Jul 22, 2008 | 11:48 AM
Ludikraut's Avatar
IMO there is no definitive setting for cam gears. Unless you are willing to spend the time and money to put your car onto a dyno and try different cam gear settings, it's not really worth it. I ran the -4/-1 settings on the HKS 272s primarily because it helped the topend a little and idled almost like stock. I suspect I probably lost about 100 RPM spoolup, but I didn't bother confirming this, since I stepped up to the 280s a year after I got the 272s. With the 280s I tried a lot of different settings and ultimately settled on the +2/0, since that had the best combination of spoolup and topend (idle be damned ).
l8r)
Old Jul 22, 2008 | 12:05 PM
GregGSC's Avatar
I just used a set of AEM's 5 bolt gears and was pretty damn impressed. much larger hardware than the fidanza. the only down side is the fact that they don't use a stud like the fidanza, so if you happen to overtighten an aem you will be rethreading the aluminum. On the other hand i have seen a couple of the fidanza gears that have had bent studs.. which leads to broken studs, which leads to pistons and valves making out....
Old Jul 22, 2008 | 12:43 PM
l8r)
Yeah thats what Im planning to do. go to my friends dyno and play with those gears.What kind of turbo setup you had when you installed the gears? Im running a 35r.thanks.
