Best Cam Gears On an 8 ....???
Old Jul 22, 2008 | 01:42 PM
03whitegsr's Avatar
I ran the Fidanza gears for about 40,000 miles on my last 4G63. Like Greg said though, the hardware is pretty small on the Fidanza gears.
Pick the best cam for your application first. If you want an even better match to your needs, then cam gears can be helpful.
Old Jul 22, 2008 | 04:47 PM
Ludikraut's Avatar
Originally Posted by evo/lightning
Yeah thats what Im planning to do. go to my friends dyno and play with those gears.What kind of turbo setup you had when you installed the gears? Im running a 35r.thanks.
I ran the HKS 272 cams on the stock Evo 8 turbo. I run the HKS 280 cams with a 50 trim.
l8r)
Old Jul 22, 2008 | 05:11 PM
Boost3dxEvO's Avatar
stock cam gears.......
Old Jul 22, 2008 | 11:14 PM
nightwalker's Avatar
I've seen cam gears break. You willing to chance that?
Old Aug 4, 2008 | 04:09 PM
2k4EvoVIII's Avatar
Originally Posted by GregGSC
I just used a set of AEM's 5 bolt gears and was pretty damn impressed. much larger hardware than the fidanza. the only down side is the fact that they don't use a stud like the fidanza, so if you happen to overtighten an aem you will be rethreading the aluminum. On the other hand i have seen a couple of the fidanza gears that have had bent studs.. which leads to broken studs, which leads to pistons and valves making out....
Greg:
You thought of making your own set of cam gears? If so how much so i can send you some money to get a set going....
Chris
Old Aug 20, 2008 | 08:36 AM
Elu's Avatar
Elu
Damn I was gonna purchase some Fidanza cam gears, too. I ended up seeing something like this http://fidanza-is-crap.com. Any thoughts on BLOX cam gears? Reliability? Or do all cam gears have a higher failure rate than stock?
Old Aug 20, 2008 | 03:26 PM
Ted B's Avatar
It's really quite simple.
Aftermarket cams are timed all over the place. Anyone who believes that all these cams makers invested countless days of hands-on research trials to successfully optimize the settings to meet all applications is living in a fantasy world, because no such thing exists.
Cam gears are best suited and most effectively used by those who either:
(a) Know how cam timing affects power delivery
(b) Are willing to learn how cam timing affects power delivery
(c) Want to tweak their setups to maximize performance for the intended usage
Not everyone wants to take this step, and that's just fine. It definitely isn't for everyone.
Old Aug 20, 2008 | 04:35 PM
skk72's Avatar
Originally Posted by PedroMartinez
Hey guys . I was wondering what are the best cam gears to purchase for an evo 8. Or does it really matter as much as cams? I have searched but really cannot find the answer i want. I have Tomei Pro 280 cams and would like a Nice set of Cam Gears that match my good cams . Also have an AMS 35r kit.
So the question is simple . what are the best Cam gears I could buy ?
if you have tomei camshaft why not go with tomei cam gears as well
http://www.tomei-p.co.jp/inf/pdf/56_ae_Letter.pdf
Old Aug 20, 2008 | 04:49 PM
evo ippo's Avatar
i rock tomei if i was running tomei cams
Old Aug 20, 2008 | 08:20 PM
SpoolnupTuning's Avatar
stock!! no need for more parts that will break!
Old Aug 20, 2008 | 08:26 PM
Billy@EnglishRacing's Avatar
it doesn't really matter, not even as close to cam choice, just get a set of aem gears and call it a day
Old Aug 20, 2008 | 08:32 PM
David Buschur's Avatar
Use the stock ones.
Old Aug 20, 2008 | 08:34 PM
If your going to run the cams straight up stock would be the way to go.
Nelissen
411
Aug 13, 2024 02:06 PM
TwistedEvo8
26
Aug 7, 2016 06:48 PM
ryukinevo
Aug 11, 2011 10:10 AM
Carrier
Lancer Engine Tech
Jan 9, 2007 09:56 PM
Seba
43
Oct 17, 2006 07:44 AM
