Megan Manifold Problems
Old Jul 25, 2008 | 02:23 PM
Most-Wanted's Avatar
I know it has been discussed, but just wanted to give my latest discovery. I found a tiny crack in mine and dynoed back to back with a stock one. I gained 10 hp and 20 tq by installing a stock exhaust manifold. It is my suggestion to anyone that has a Megan exhaust manifold to throw it out and buy a ported Buschur unit. The one I borrowed(thanks Ryan and Felix) for the test was partially ported by the owner. I would've liked to try a BR ported, but we needed to continue dyno testing.
Old Jul 25, 2008 | 03:36 PM
k2boarder3187's Avatar
my megan has a crack in it
debating to buy a used stocker and get it ported and coated...
any difference at all with the IX and VIII stock manifold? i dont think there is but im just checking.
Old Jul 25, 2008 | 03:38 PM
jmartinez1170's Avatar
I had mine for over 2 years not one crack or problem with it. And i pushed my car hard every day i drove it.
Old Jul 25, 2008 | 06:51 PM
selp's Avatar
i have sbr tubular manifold and i don't have a crack.
but i still have my stocker in case i need it. good back up plan
Old Jul 25, 2008 | 07:12 PM
David Buschur's Avatar
Thanks for the info. I have tested some of the headers a few years ago. I found the same thing.
Old Jul 25, 2008 | 07:23 PM
max2evoix's Avatar
megan mani's are junk
Old Jul 25, 2008 | 07:34 PM
1NastyMR's Avatar
megan is junk agreed
Old Jul 25, 2008 | 07:41 PM
quick silver 8's Avatar
i took mine off a months ago and never looked back. as whitney houston said "crack is whack"
Old Jul 25, 2008 | 07:56 PM
No problem. I would've liked to just of installed yours, but it is almost time to send the RS up there so need to waist the time on it. I am running the car one more time and it is good night on the stock turbo stuff.
Old Jul 25, 2008 | 08:02 PM
EvoHung's Avatar
This sucks. I don't have the megan manifold but it might as well be. I have the xs-power, which started to crack on me as well.
Most Wanted, your times are insane!
Old Jul 25, 2008 | 08:10 PM
How much money you want to bet that if you installed a BR ported you see at least 5hp and 10tq more? I'm not going to get into a debate here, but pull it off and look at the inside along where the runners are joined and tell me what you see It cracks there as well and you can't even see that its cracked. I've given my advice, you can ignore it if you chose.
Old Jul 25, 2008 | 08:25 PM
evoPirate's Avatar
over 3 years and never a problem with mine *shrug*
Old Jul 25, 2008 | 08:57 PM
MrJdmJimi's Avatar
megan is junk if you are trying to make good power with ... i have a stock cast one for sale..
Old Jul 25, 2008 | 10:29 PM
johnhwfd's Avatar
Ive had mine at least 2 years and its fine. All tublar manifolds get cracks even the most expensive ones. Everyone that I know that tested there's got about a 10 to 20 hp and tq gain with the Mani alone. U be the judge. You can spend two or three times as much it dosent mean it won't crack.
Old Jul 25, 2008 | 10:35 PM
goevox's Avatar
try to get a new one under warranty.
