Help, I can't split transfercase from tranny evo9
Old Jul 26, 2008 | 09:47 AM
piotr4net's Avatar
Hi All, I have big problem . I wanted to change clutch. I stopped on
split transfer from tranny, on the pict. I cant move it any more.
What to do? What could happen ?
Nothing stop transfercase, allaroud removed (shafts)
Picture:
Old Jul 26, 2008 | 09:50 AM
jmelocik's Avatar
I'm at work and can't see the picture but did you remove the stub shaft?
Josh
Old Jul 26, 2008 | 09:54 AM
piotr4net's Avatar
Josh
What You mean "stub shaft"? shaft to wheel removed and shaft to read diff removed
Old Jul 26, 2008 | 09:56 AM
1320 Engineering's Avatar
is it hitting on the cross member?
pull harder!
Old Jul 26, 2008 | 10:03 AM
Silver05Bullet's Avatar
there is a input shaft that goes thru the tranny and conencts to the actual tcase, the other end of it connects to the axel you have to pull that one out
Old Jul 26, 2008 | 10:18 AM
piotr4net's Avatar
pull harder!
What You mean cross member? I was afraind to hit anything. Only
insert wood between tc and tranny and try move to trany and back (like on the picture)
Is there any lock on shaft or sth like that?
ps. crossmemebr removed
Old Jul 26, 2008 | 10:24 AM
sabastian458's Avatar
lift up under the transfer case. you are being hung up on the 2nd set of splines going into it. You might have to rotate the bottom of the case back and forth. Once it is loose, it will drop down.
Old Jul 26, 2008 | 10:25 AM
have you by chance already removed the transmission bolts holding it to the engine? Some of the movement need to remove the case is gotten by moving the transmission.
Old Jul 26, 2008 | 10:32 AM
ak47po's Avatar
Old Jul 26, 2008 | 10:41 AM
feautoevo's Avatar
If you haven't removed the "input shaft" which looks like a mini half shaft that is completely internal the tc won't budge send me a pm with your phone number and mabey I can clarify
Old Jul 26, 2008 | 10:48 AM
If you can not see thru the hole in the transmission and transfer case where the axles attach, then the shaft is not removed.
Old Jul 26, 2008 | 11:01 AM
feautoevo's Avatar
515-571-1288 If you still need help My name is Brett
Old Jul 26, 2008 | 11:09 AM
piotr4net's Avatar
Brett , thanks a lot, but I come from Eastern Europe, and my English is very bad, I afraid I will not understand You
Old Jul 26, 2008 | 11:46 AM
piotr4net's Avatar
should I remove red shaft?
Old Jul 26, 2008 | 11:49 AM
you actually have to pull it out, but yes that is the shaft. I maybe mistaken on my earlier post, you might not be able to see completely thru the transmission, but you should be able to see the diff inside it.
