exhaust leak
Old Jul 28, 2008 | 03:59 PM
shawn360h's Avatar
exhaust leak
So saturday night i was driving home from my friends house and i start to hear this slight ticking noise. I go to drive it the next morning and its even worse i thought i might have a boost leak. I tighten the ic pipes on the ic and that doesn't fix it. I then come to find out the gasket between the header and turbo is blown out on the passenger side. Now my question is what could have possibly caused this all the nuts and bolts were tight? Could it have been because my o2 housing doesn't have a support backet ( which i am currently getting welded on)? Any input would be great
Old Jul 28, 2008 | 06:37 PM
silver_evo's Avatar
Could've been an old gasket, did you replace it and torque the bolts properly when you installed the header and o2 housing? The factory specs:
Old Jul 28, 2008 | 07:10 PM
IXmr321's Avatar
It may have been nothing that caused it, gasket could have just been bad. I remember when I put the megan manifold on TTP told me not to use the megan gasket. Try getting a Mitsu gasket and replacing it
Old Jul 28, 2008 | 07:41 PM
SLO-EVO's Avatar
with the above torque specs, i would recommend checking that all of the bolts are tight... if they are, take them off, and check the gasket... if you have soapy water, and a cooler engine, you can find it pretty fast... a friend of mine's gasket between the exhaust manifold and turbo was blown. he high-temp rtv/ jv welded it... a temp fix, but not recommended
Old Jul 29, 2008 | 09:51 AM
Davethewave's Avatar
i just reused my oem gasket, granted it didnt have that many miles on it, but the main reason was because i was being cheap. its bean holding true ever since.
Old Jul 29, 2008 | 10:34 AM
JakeTheVIII's Avatar
+1
The Megan gaskets are crap. The stock gasket between the manifold and turbo is nice and thick. I used to run a copper exhaust manifold gasket and it crapped out so I switched back to stock. Running great ever since.
Old Aug 4, 2008 | 01:38 AM
azinterrider's Avatar
the Megan gasket is def bad, had that gasket explode on me, oem is the best
STi2EvoX
49
Nov 21, 2015 06:26 AM
GTijoejoe
Jun 5, 2012 08:30 AM
fox2boost
Sep 19, 2007 11:14 PM
PKEVO8
12
Sep 6, 2006 03:09 PM
fareastkorean
May 10, 2005 07:42 PM
