Whistling Sound?
Old Aug 30, 2006 | 06:29 PM
PKEVO8's Avatar
Whistling Sound?
Well about an hour ago I was leaving a friends house and all of a sudden i noticed some strange "whistle" everytime i would release the gas. It sounded as if it was coming otu of the bov. As I drive home, I notice that the whistle pitch gets higher with more rpms. And everytime i would let go of the gas, the whistling would die down until nothing was heard. I don't think this is a boost leak, because it doesn't really sound like a hissing. My LICP fell off a little while ago while I was at the track. Could that have anything do do with it? The sound almost sounds liek a tea kettle thats starting to whistle, and after you take it off the stove, it dies down. I've been driving the car all day, and haven't heard that sound once. Mods include, XS IC, XS UICP & LICP, agency power intake, mbc, Forge Atmospheric Dump Valve, and APS 3" TBE. (turboxs utec road tune)
Old Aug 30, 2006 | 06:39 PM
PKEVO8's Avatar
bump
Old Aug 30, 2006 | 06:43 PM
smokedmustang's Avatar
You can't "bump" 10 minutes later!! You are still on the main page!! Boost leak, gotta search on this one, I am too tired.
Old Aug 30, 2006 | 06:45 PM
PKEVO8's Avatar
lol, i just really wanna know! but the problem is that i'm not loosing any boost...
Old Aug 30, 2006 | 06:50 PM
hondafan's Avatar
you can still have a leak and not lose boost, your turbo just works harder to supply that amount of boost.
Old Aug 30, 2006 | 06:54 PM
PKEVO8's Avatar
alright thanks! I'll look around a little bit tonight and see if there is any noticeable leak, but if not, I'll just use that boost leak tester from smokedmustang's thread. Thanks for the help guys.
Old Aug 30, 2006 | 06:56 PM
SpinOne05's Avatar
Check for a leak, a whistling noise is key here. What can make a whistling noise? Boost leak, air moving past something.
Old Sep 1, 2006 | 02:13 AM
Did you find the problem? I am awake and ready to help you solve the problem. I will check back later!! Use the boost leak tester, I say you WILL find your problem!
Old Sep 1, 2006 | 02:15 AM
1. A Parrott
2. A Refferee
3. An annoying passenger hung up on show-tunes.
Old Sep 1, 2006 | 08:15 PM
PKEVO8's Avatar
well i tried to do it at around 3 in th e morning, with no luck. Partially because i didn't have everything i needed, and partially because i was falling asleep half the time. But it will be in the shop tomorrow waiting for a new turbo mainfold. So while its there, the shop is gonna do a "thorough" check for leaks. I think i may have found the problem though, coming from some hosing form the bov. But, I will know for sure in the near future. Thanks for all the help. Oh and i just noticed what time yous ent this. If only i was up an hour longer....
Old Sep 5, 2006 | 10:10 AM
Xenope's Avatar
Did you find out what was wrong?
Old Sep 5, 2006 | 02:43 PM
PKEVO8's Avatar
kinda, sorta not really. From what i did befor ei left it at the shop, i found no leak. Today the bov was taken apart to check foe gonna do r any problems with the internals and nothign was wrong. So the guys at the shop are going to do some more tests for leaks, check the turbo and try and figure out the problem. If the turbo bllew, then i guess you guys had better help me figure out which turbo to get. Car is gonna be tracked often, road racing, time attack, etc. any suggestions?
Old Sep 6, 2006 | 03:09 PM
PKEVO8's Avatar
ok well to all who have helped me, it was not a boost leak, nor internal p[roblems with the bov. Nor were there problems wiht the turbo (sob, coulda bought a 50 trim). It turned out that some bolts got loos on the gasket, and so, a new gasket will be coming soon. But, thanks a lot for all of your help guys.
commbubba19
Oct 11, 2016 07:37 PM
Pavien
Feb 12, 2016 01:18 AM
02lancerblue
Lancer Engine Tech
17
Aug 26, 2008 07:58 PM
JaReDbOy
15
Aug 24, 2004 07:38 PM
masterevo
10
Apr 23, 2004 06:17 PM
