EVO engine idle vibration
Old Aug 21, 2003 | 03:58 PM
EvoNick's Avatar
OK, I'm on my 2nd EVO, and while this one doesn't have the decel/grinding noise the last one did, it does seem to idle a lot more harshly. I get a vibration I can feel thru the seat and the steering wheel that I would consider bordering on unacceptable.
What is everybody else's experience?
Old Aug 21, 2003 | 04:58 PM
IzenGreyEvo7's Avatar
The Evo has very stiff engine mounts and this should be normal. It's very subjective as to what constitutes harsh vibration. This is a raw performance car. It's one of those compromises you make, along with squeeky brakes, loud cabin noise, etc..
Old Aug 21, 2003 | 06:02 PM
Dale_K's Avatar
What happened to the first EVO?
Old Aug 21, 2003 | 06:32 PM
MYEVOVIII's Avatar
Push in your clutch if it goes away it might be your throw out bearing. But good luck on getting Mitsubishi to fix it.....
Old Aug 21, 2003 | 07:12 PM
AvatarOfWar's Avatar
I get it to, but it doesn't bother me. I noticed that every now and then the rpm's will dip into the 700's (watching my monitor on the SAFC). That is when it happens, it usually happens when I have the air conditioner on. Hell, I'm used to my old blown Mustang dying at idle randomly, this is 10x better
Old Aug 21, 2003 | 07:31 PM
CLeeEvo's Avatar
I feel lots of vibrations too when the car is idle. It almost feels like engine knocking every 3 seconds. But it rides smooth so I guess it only happens at low RPM's.
Old Aug 21, 2003 | 07:33 PM
Keyser Soze's Avatar
Haha... i guess this is why i have not really noticed it in my car... If i have this vibration it is not/would not be an issue to me
Old Aug 21, 2003 | 09:34 PM
EvoNick's Avatar
http://gallery.evolutionm.net/showga...=1&ppuser=9041
Old Aug 22, 2003 | 04:46 AM
kdogg's Avatar
Mine only does it with the AC on. As soon as I turn the fan off, the RPM's go back to normal. Kind of annoying, but I've accepted it's a high peformance engine. Is there a fix for this? Like more powerful battery, alternator, or AC comperessor....
Old Oct 10, 2005 | 07:37 AM
4cdndctn's Avatar
I wonder if your noise's' are related to mine...
-I have an MR, stage 4 which I believe and hope to be unrelated-
When idling, every so often, my engine sounds like a brokenwashing machine...An old one.
It sounds like a hydraulic issue that cycles every second, and my floor shakes like mad.
Good news, my RPMs, voltage, and temps remain uneefected, but I cannot source what it is!
Thoughts?
Old Oct 10, 2005 | 09:44 AM
RyanM's Avatar
For the AC problem--a grounding kit will help, clean your battery terminals too--they could be corroded. You might want to bump up your idle 100rpm if its almost stalling.
Old Oct 10, 2005 | 10:13 AM
kdogg's Avatar
Thoughts?
Holy old thread! Anyhoot, you might to spell out what your "stage 4" consists of?
Old Oct 10, 2005 | 10:19 AM
w2pac12345's Avatar
quick fix..... Stop your whining, sell your car, and then buy a civic.
Old Oct 10, 2005 | 10:21 AM
RyanM's Avatar
The new 2006 Civic SI doesn't suck
Old Oct 10, 2005 | 02:17 PM
ev08buoy's Avatar
I agree on that one
