SparkTech Fixed my Misfire on stock ECU
Old Jul 29, 2008 | 10:15 PM
Lucas English's Avatar
So as many of you know I make 506whp and run 10.9@126 on my stock IX turbo with stock ECU,ignition full weight SSL.(3450 with me)
For my car to handle the 33psi spikes I had to run a .019-020 plug gap. If i ran Iridium plugs I would get about 1500-2000mi before I would start having misfire problems. Copper plugs would go about 500mi.
So I installed the SparkTech PRO 12 M&W CDI system on my stock ECU car last Friday and it did more for my car then I ever thought it would.
I was amazed the car went from a extreme breaking up to smooth as can be on the same copper plugs. I ran the car at the track that same night. Car ran the same times but on the what were bad plugs. I will start playing with bigger gaps next week to see what that does.
Install of this Ignition was cake. Just hooked up the pos and neg to the bat and the rest was plug and play with the factory wiring harness and I made no changes in the tune.
Old Jul 29, 2008 | 10:31 PM
sspaladin28's Avatar
Plug and play with stock ECU huh, fantastic!
Old Jul 29, 2008 | 11:55 PM
Steveevo9's Avatar
Just an amazing vehicle, that is some awesome tuning right there. Is this also a daily driver, well done .
Cheers Steve
Old Jul 30, 2008 | 05:01 AM
MR Turco's Avatar
What copper plugs were you using?
Old Jul 30, 2008 | 05:08 AM
DBallz's Avatar
From: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
I'm wondering myself too. I used copper plugs on my 2000 Turbo Si and I would go about 6k before I would start to misfire. Oh and before the blow tourch gets set on my butt. The civic was daily driven 650whp I'm not sure how that translates from Honda to DSM but it should be the same I was running a 35r and mild motor build
Old Jul 30, 2008 | 05:19 AM
MR Turco's Avatar
i am curious because i have yet to see a confirmed copper plug for the IX head.
Old Jul 30, 2008 | 05:33 AM
raiceboi697's Avatar
the more i read about this the more i want to break down a buy one
Old Jul 30, 2008 | 06:11 AM
MRfabolous's Avatar
it says under his user name he has a 04 ssl he might have upgraded to a IX turbo for his 8 that is why he is using coper plugs with his evo VIII head and not a IX
Old Jul 30, 2008 | 06:33 AM
MR Turco's Avatar
oh you are probably right.
Old Jul 30, 2008 | 06:44 AM
BPR8ES and BPR7ES are the copper plugs I have tried and yes the car is a 2004.
Old Jul 30, 2008 | 07:17 AM
dudical26's Avatar
Does the car stumble or misfire at all at during daily driving?
If you didn't know you installed the COP, would you be able to tell its there(aside from not breaking up at high boost)
Old Jul 30, 2008 | 07:29 AM
Paul Nelson's Avatar
Nice Work Lucus!
SparkTech's Avatar
Thanks Lucas...glad we were able to solve your misfires.
Wow how time flies...our new Pro-systems now features under plate wiring for an even cleaner install. Pm me and we'll discuss getting you a new and improved harness
Old Jul 30, 2008 | 07:52 AM
Well the car feels totally stock but with no top end miss. I have put about 150mi on the car so far with the pro12. I will report back in a few weeks if I notice anything different.
QUOTE=dudical26;5947997]Does the car stumble or misfire at all at during daily driving?
If you didn't know you installed the COP, would you be able to tell its there(aside from not breaking up at high boost)[/QUOTE]
Old Jul 30, 2008 | 10:22 AM
dudical26's Avatar
[/QUOTE]
Thanks for the info. Please do update us after more driving to see if you notice any unusual behavior
