Clutch pedal squeeking/binding
I noticed that my clutch pedal is making weird noises close to when its all the way in, I applied some lube and re-adjusted the pedal and it helped a little but the noise came back.
I have the restrictor pill removed and running stainless line, the clutch engage smoothly with no shifting problems, just that annoying sound when its being depressed.
You guys think its my clutch master cylinder or slave? I'm planning on re-bleeding it and putting in new fluid and hope it helps.
Any experience w/ this issue please post or any suggestion will be very helpful, thanks in regards!
