wheel baering issue... help
Old Aug 1, 2008 | 11:20 AM
Malik_EvoIX's Avatar
this might be in the wrong section but w/e, i just got my car back from local speedshop, they put a new clutch in it and now this happened. thy are blaming me for it when they had my car. the car makes a noise. wheni was dropping my car off it didnt make no noise what so ever!!! how did this happened?
Old Aug 1, 2008 | 11:36 AM
bump help please i need info
Old Aug 1, 2008 | 11:39 AM
justboosted02's Avatar
clutch install wont make your wheel bearing go bad
can you describe the noise you are hearing? does it sound like a low flying helicopter when turning?
Old Aug 1, 2008 | 11:44 AM
when giving gas or even cruising with no gas makes that noise
Old Aug 1, 2008 | 11:45 AM
and about the clutch install what if they did a really ****ty job?
Old Aug 1, 2008 | 11:47 AM
unless they took your car out and beat the crap out of it and did some doughnuts then it probably just a coincidence
that is weird though, usually when a bearing goes its gradual
Old Aug 1, 2008 | 11:50 AM
there really is no way to damage the bearing as its encased in the knuckle, idk what they did.
usually bearings go bad from repeated high g turns (read autox) or other similar abuse
how many miles are on your car?
Old Aug 1, 2008 | 11:58 AM
Billy@EnglishRacing's Avatar
If they moved your car with out the axles that could do it, but i highly doubt that happened. I think it was just time for yours to go, i have seen some go out in very low mileage evos.
Old Aug 1, 2008 | 12:06 PM
MyEvoRocksUrv8's Avatar
same thing happened to me....just order a new wheel hub assembly. I believe it's 164ish from mitsu.
Old Aug 1, 2008 | 12:07 PM
call Russel at mitsuparts
Old Aug 1, 2008 | 12:42 PM
only 26k never been to an auto x event
Old Aug 1, 2008 | 12:43 PM
when i complained and my friend went undercover to the shop in his STI they were talking ahit about me and laughing at me behind my back!!
Old Aug 1, 2008 | 03:07 PM
well im glad i dont live in Michigan then
that sucks
Old Aug 1, 2008 | 03:15 PM
k2boarder3187's Avatar
i have a used wheel bearing if interested
Old Aug 1, 2008 | 03:23 PM
take 'em to court son!
