3582HTA vs 6265 Dyno Comparo
Old Jan 9, 2009 | 10:15 PM
  #121
ScorpionT's Avatar
Originally Posted by Mike@AwdMotorsports
Stay posted Ted b.. Ill have the 1st 6062 billet in my hand soon.. If it out spools the 6262 we ran 8s with it will be a great turbo.. It'll make 700 no problem..
The race is on! I ordered a pair already for a TT 350Z. Ditching the pair of 6262 to see how much quicker they come into boost, trying to make an even better DD.
Have you ordered the 6765 yet? Im getting one to try on a Supra Im guessing they will destroy the standard 67mm its replacing, just like the 6262 vs 35R.
Old Jan 10, 2009 | 04:51 AM
  #122
less10's Avatar
Biased testing anyone!!!
Dyno's are only half truth, you could have loaded the dyno differently to make it read differently and appear like the hta makes more than the 6265. If the 6262 is a smaller turbo than the 6265 and the 6262 just went 8's. Where is the hta that has gone 8's before it? Doesnt bushcur run hta stuff?
Old Jan 10, 2009 | 07:37 AM
  #123
4G63DSM's Avatar
Originally Posted by ForcedPerformance
82HTA vs the 6265 turbo on the dyno, my results.
The 82HTA compressor is a 59mm inducer, while the 6265 is larger at 62mm. Both wheels are billet, but not equal. The HTA wheels are made in 2000 series aluminum while the PTE ones are only 6061 aluminum. Grab your material science text book and look how different the strengths of these two materials are at a typical operating temp of about 400F.
6061?? are you kidding? at speeds that turbo's spin,, 100,000 + rpm, I'm surprised a 6061 series al would last more than 5 min!
scary...
2000 series must be a pricey chunk of billet, but damn worth it!
Old Jan 10, 2009 | 08:04 AM
  #124
EVO8_PR's Avatar
I'll be going from a standard GT35R@32psi to a Precision 6262@ somewhere in the mid to high 30's. I hope to see a noticeable horsepower gain.
Old Jan 10, 2009 | 08:14 AM
  #125
borievoinitialD's Avatar
bad *** comparison, thats why im getting my fp green when i have the cash!!
Old Jan 10, 2009 | 08:30 AM
  #126
Turbo Kyle's Avatar
Nice work
Old Jan 10, 2009 | 08:36 AM
  #127
ScorpionT's Avatar
Im with you on that! I like how the dyno posted shows the 82HTA making more power than a 6265, but somehow a lower flowing 6262 outgunned the 86HTA. Doesnt seem to make any sense, does it? It looks like boost was changed or dyno numbers were messed with. I just dont see that turbo spooling later, yet making less power.
I understand the reference of 6000 series aluminum to 2000 series, but Ive used Precision 71mm before, and I know tons of guys that run them and no problems so far. These are also Supra guys who run high boost and race fuel all the time.
Old Jan 10, 2009 | 08:58 AM
  #128
CO_VR4's Avatar
There are lots of reasons that two dyno tests done on different dynos, with different cars, at different times with four different turbos could reach results that would confuse someone who assumes performance characteristics between different turbos in the FP and PT families and then extrapolates that different results should have happened. Why you'd ASSume that the FP dyno results were changed, but accept the Mike AWD dyno tests as gospel is beyond me...
Ted B. is dead on. When you read these results, ask yourself how much they tell you about what a turbo would do for you on your own car. How many of us are going to be running 40 PSI ever, much less on a regular basis? Find the turbo that works well in the parameters you'll use. For the vast majority of people, I bet that a turbo like the 82HTA seems to be very well documented as a winner...
Old Jan 10, 2009 | 10:05 AM
  #129
ScorpionT's Avatar
If the dynos were done at different times with different cars, etc... they cant be overlayed and show valid results. I have an interested way to look at things. SP makes the TT Z kit with Precision 61mm(35r) turbos. You can upgrade to much better flowing 67mm turbo, OR you can upgrade to the 6262 which blew away the 67mm on the dyno. A 6265 makes even MORE power than a 6262. But somehow the 82HTA makes more power and seems to hold boost better as the dyno shows. Ive also seen the 3562(35R, 62mm compressor) make more power with better response than a 35R.
I also agree with Ted, pick the turbo for your application, thats what I always tell people. Im all for using the best products, so Im always on the hunt for the newest and best thing. I just dont see the validity of testing a 6265 and an 82HTA back to back, lag will be much different. The PTE unit is larger, and the 6062 is a much better comparison.
I want to see unbiased comparisons with comparable turbos. The FP spooled quicker, but its a smaller turbo, so I would expect those results. I want to see 6062 vs 82HTA, and 6262 vs 86HTA. If the FP shows to be a better turbo, thats what I will be using.
Old Jan 10, 2009 | 10:17 AM
  #130
slowTsi's Avatar
Originally Posted by Ted B
True, but not all planning revolves around where the compressor ultimately chokes.
A sound plan is one that involves defining a power target and choosing a turbo that is capable of attaining that figure with available fuel, with the least amount of compromise in the way of low speed power and spool characteristics. This maximizes average power, and it is average power (not peak) that delivers real world performance. If 600whp were the power target in this case, the HTA3582R outperforms the 6265 because it delivers greater average power. Even if the 6265 had something left beyond the HTA unit, it would have to deliver significantly more peak power to make up for the greater average power of the HTA turbo.
With the HTA3582R being capable of over 700whp, there seems to be nothing around that gives greater power potential without giving up something.
The point was made by Robert that the HTA car would win in a race when subject to the same boost level. People who want a 700+whp car surley take choke flow limits into account, and if you are opne of the select few that doesn't then you are a bench racer that wants an dyno sheet with "x" whp and decent spool.
Also, I am pretty sure everyone and their grandma knows you give up low end to gain high end, which makes this test seem even more like marketing. I am sure Robert knew which one would spool sooner
Old Jan 10, 2009 | 10:52 AM
  #131
zedevo's Avatar
Nice Thread ...
Old Jan 10, 2009 | 12:14 PM
  #132
Ted B's Avatar
I want a 600whp EVO that can attain that figure without spinning the compressor to its limits, while having a broad torque curve and best possible transient response. The obvious choice was an HTA3582R in twinscroll configuration, and I have yet to see anything better suited to the task. The fact that the turbo can be pushed somewhere beyond 700whp is irrelevant to my power and longevity targets. I don't quite see how that makes me a 'bench racer'. I feel a term like 'rational individual' is more fitting.
'Everyone and their grandma' knows getting something costs something else, but that is true only in a broad sense. Advances in technology defy that rule, and in this case, it comes as a result of swapping a more efficient compressor onto an already efficient turbine.
Old Jan 10, 2009 | 12:59 PM
  #133
EVO8_PR's Avatar
OK, so the HTA GT3586R will make more power @ lets say 35psi than a Precision 6262 @ that boost level ?
Old Jan 10, 2009 | 01:45 PM
  #134
TopLevelPerformance's Avatar
Wow Precision is not playin with these new turbos, lookin forward to seein that 6062 test Mike
Old Jan 10, 2009 | 01:48 PM
  #135
900hp cabable in a t3, dam technogly has come along way big time.
Cant tell you what the 6262 at 35 psi makes but at 49psi it holds boost pretty decent only dropping to 46psi and makes near 800whp in hot florida heat.. My opinion is its the superior t3 turbo to date.. just wait til the 6765 billet wheel is released.. near 900whp on a t3 has never been done.. I think it will do it..
