My Evo 9 made popping sound w/ black smoke and oil leaking from o2 housing.
HKS Carbon Ti Exhaust, UR Test Pipe, Helix Version 2 downpipe, Megan O2 housing, PPI ported manifold, Hks Mivec Cams, ARP Headstuds, Turbo XS Fmic, Nisei LICP, Turbotrix UICP, Aem Intake, Apexi filter, Act SD clutch, SS clutch line, Lancershop short shifter, Kartboy bushings, AGP front motor mount, Agency Power cam gear motor mount, Aem Uego Wideband, Aem Tru boost gauge
sucks bro
I would def take a look at the turbo... even though it was the block that let go. You get metal in the turbo. Also chances are the valves are bent in the head. Once the rod exited the motor .. the piston if on the upstroke .. keeps going and hits the head. ( resulting in bent valves )
mark
turbotrix
mark
turbotrix
I was hoping it was the turbo...
I have no idea how it happened since he is only on bolt-ons,cams and NO meth. I am assuming it was detonation
