porting on 10.5 housing
Old Aug 6, 2008 | 02:50 PM
SpoolnupTuning's Avatar
I recently got to play with a fellow evo owners 10.5 housing and thought i would show some pictures. As I started with buschur's porting job, it didn't look that bad! But I wanted it to be as smooth as if it was polished So first pic is buschurs porting, which is very nice. The only thing that bothered me was i could feel rough edges as i run my finger through it!
So then i preceded to pull out the sanding wheels and go to work, I didn't really have that much time in it. The hardest part was to get every little grove the same! My sanding wheels come in multiple grits of sand paper as for I started with 60 and went to 120 grit. At first I didn't think it would be that smooth with 120 grit, but i think it turn out very nicely and very smooth! So on to the pics!! Enjoy
My next big project is the stock rough cast manifold. Hopefully i can get it as smooth all the way through. By the way the car si going to the dyno to see if it helps spool or power, hopefully it will help out every where!!
Old Aug 6, 2008 | 02:53 PM
Wicked E's Avatar
well dang! Nice job!
You got a PM!
-E
Old Sep 26, 2008 | 04:55 PM
warp9's Avatar
Nice job on that hotside! Is the IX 10.5 hotside interchangeable with the Evo Red?
Old Sep 26, 2008 | 05:42 PM
MR Turco's Avatar
The hotside is actually very close to gasket matched, enough not to need a ton of work. The exhaust manifold however really needs some time invested in it. It is really a poor casting, lots of room for improvement. This is some really nice work though!
Old Sep 26, 2008 | 06:48 PM
Spish's Avatar
How much of a difference would this make? If its worth it I might do the same.
Old Sep 26, 2008 | 06:51 PM
MR Turco's Avatar
I dont think it is worth removing the hotside just to do this but if you have it off or are doing the O2 housing and have the tool available i would definitely polish it.
bluewaterDEMON
204
Apr 3, 2014 08:14 PM
vtlaxplaya16
Feb 27, 2006 11:01 AM
vtlaxplaya16
Jan 28, 2006 12:17 AM
