500 to 600whp drop in setup.
Old Aug 7, 2008 | 07:51 PM
AcePitcher11's Avatar
Well the head is off my car right now and I have decided to go ahead and drop some pistons and rods or maybe just rods in. My setup should net 500whp on pump and close to 600whp on race gas. What are the most affordable rods and pistons solid enough for this power? And are pistons really necessary or are replacing the rods enough?
Old Aug 7, 2008 | 08:01 PM
whitey4d's Avatar
I would use the BR spec JE pistons that are meant for the stock bore. I think the Crower rod would be a good choice, they also offer an aluminum rod aswell.
Old Aug 7, 2008 | 08:23 PM
SickSilverNLow's Avatar
My combo would be JE and Oliver .
Old Aug 7, 2008 | 11:33 PM
Nissan2Evo's Avatar
I'm doing a drop in build now..prepping for the 37R. I bought all Buschur components for my engine. Goal is 130-137 traps on meth, 140+ traps on race gas. I'll let ya know it goes. But yea..the Buschur JE/ Crower rod combo is fantastic.
Old Aug 8, 2008 | 12:12 AM
konstantinosIX's Avatar
I think that these trap speeds is possible with 35R also.
So why R U thinking of a laggy 37R instead of a 35R?
Old Aug 8, 2008 | 03:25 AM
Nissan2Evo's Avatar
Dude, just PM me with a question like this if you're really that interested rather than thread jacking the OP
Old Aug 8, 2008 | 03:33 AM
vaflyboi757's Avatar
I'd say since you're already in their go head and change em. I actually gonna do a drop-in a few months, I'm goin with Wiseco and Manly.
Old Aug 8, 2008 | 03:40 AM
Ev0cRaZy's Avatar
I have Wiseco+Crower
Old Aug 8, 2008 | 04:28 AM
deadbeatrec's Avatar
i have wiseco and eagle right now with 504whp 456tq
Old Aug 8, 2008 | 05:31 AM
supersal's Avatar
Wiseco Pistons and Eagle Rods are a popular affordable combination.
for 500HP I would say the Stock Pistons are good enough...
For 600HP I'm not so sure... With a good tune and no major det you might be able to get away with the stock pistons.
Replacing the Rods is a wise decision as rod failure damages blocks, so at a minimum for 500HP I would at least change the rods almost any aftermarket Rod is better than the stock ones: Eagle, Scat, Helix, etc...
Old Aug 8, 2008 | 06:46 AM
StevenStarke's Avatar
you have to change both if your gonna change one. Aftermarket rods and pistons are setup for floating wrist pins while stock isnt.
Wiseco or CP/Eagle is the cheapest and best alternative up to about 750whp. I've seen them actually handle way more then that, but 750whp is definitely a Safe boundry.
I like Wiseco and CP better then JE as the JE has a lower silicon content and that causes them to expand and contract more then other brands. That causes Piston slap when the motor is cold and it can smoke a little bit or make some noise. A rough idle can also be noticed sometimes.
Old Aug 8, 2008 | 06:50 AM
MrJdmJimi's Avatar
cp/ crower ...proven many times ..
Old Aug 8, 2008 | 06:53 AM
what rod bearing do you guys use?
Old Aug 19, 2008 | 02:00 AM
supersal's Avatar
Many tuners do modify the stock pistons to take aftermarket rods...
It is more popular in the UK though...
Old Aug 19, 2008 | 02:32 AM
4G63W8's Avatar
Guys where can I get wiseco or cp pistons for standard bore and some eagle rods at the best price?
