Need help: Lower Control Arm
Old Aug 9, 2008 | 03:36 PM
fimotorsports's Avatar
I use this slide hammer, use a 10mm bolt to put into the shaft and use the slide hammer to get it out.
http://www.harborfreight.com/cpi/cta...temnumber=5469
Old Aug 9, 2008 | 03:40 PM
1320 Engineering's Avatar
go rent a slide hammer, works wonders... one good tap and it will pop right out.
good luck!
Old Aug 9, 2008 | 07:11 PM
boostinjuice's Avatar
we have that. now we cant get the throw out bearing away from the pressure plate from the "peep" hole. the tranny is completely off but wont come off until we do that last step. it looks like its away from the pressure plate. but its not budging. it looks like its away from the pressure plate about 1/4 inch.
here is what were supposed to do
Old Aug 9, 2008 | 07:41 PM
you are going to have to have the trans flush against the block, make sure the bolts are in. If you have the trans off you can't release the t.o. bearing.
Old Aug 15, 2008 | 07:36 PM
this sucks. we cant get the tranny flush with the block.
once we get it flush. will this step be cake?
Old Aug 15, 2008 | 07:59 PM
we got it flush.
but cant get that step done!!!
Old Aug 15, 2008 | 08:11 PM
justboosted02's Avatar
talk about the install from hell
make sure when you go to relase the TOB you push the fork towards the drivers side, this will push the TOB into the pressure plate, then you can slide a flat head screwdriver inbetween the PP and the tob and pop it out. it should come out pretty easily
Old Aug 15, 2008 | 08:16 PM
thats exactly what were doing. nothing is happening.
Old Aug 15, 2008 | 08:43 PM
keep trying, sometimes it may get a little stuck. You may have better luck if someone pulls the clutch fork for you while you twist the screwdriver.
Old Aug 15, 2008 | 08:54 PM
were doing it so easy with the new unit. ugh
Old Sep 6, 2008 | 07:36 PM
VRSF Tiago's Avatar
I know this is off topic but does anyone have a part number for that bolt & nut? I've been needing it for a while now.
Old Sep 6, 2008 | 07:59 PM
rawkus's Avatar
Specify exactly which bolt and which nut.
Dan
Old Sep 8, 2008 | 07:16 PM
VRSF Tiago's Avatar
Originally Posted by boostinjuice
Replacing my clutch. We cant get the bolt holding the lower control arm out. Hammer, wrench. Nothing works.
This nut and bolt right htere that holds the knuckle onto the ball joint.
Old Sep 8, 2008 | 07:23 PM
Evoryder's Avatar
You guys have never worked on the clutch before. I did this by myself using the evomoto and it worked out. It will take some playing to get the TOB out.
