Anyone know what this thing is?
Old Aug 9, 2008 | 10:35 PM
YogSaahoth's Avatar
Veteran: Army
VIII turbo pictured:
Mine, unlike the one in the picture, is uncapped. its a hollow tube that faces outward toward the hood...wondering if this is causing the howling noise i hear when entering boost
Old Aug 9, 2008 | 10:46 PM
CO_VR4's Avatar
That's the boost source for your wastegate (or your boost solenoid if you are running stock parts).
I bet it could make quite a whistle (and lose a lot of pressurized air) if it's not connected or properly capped... I'd suggest selecting a way to cap it off if you're not using it for your turbo boost signal. Or, if you'd rather, attach a whistle or duck call to it, so you can alert other drivers that you're coming on boost
Old Aug 10, 2008 | 03:36 AM
hokiruu's Avatar
Hehe yes. the question now is: What, if anything, ARE you using a pressure source for your wastegate?
Old Aug 10, 2008 | 06:00 PM
YogSaahoth's Avatar
Veteran: Army
i tapped the bov line for my mbc install...this must have been capped and then lost it later somehow. im gonna just put a rubber cap over it..looks to be 4-5mm yeah?
Old Aug 11, 2008 | 06:33 AM
hokiruu's Avatar
Using the DV/BOV line as a pressure source is less than optimal IMO. Use this instead.
Old Aug 11, 2008 | 07:51 AM
gsrboi80's Avatar
You should tap the source that is plugged in his picture but honestly there is no difference I have as have many T'd the DV line and it works 100% fine
Old Aug 11, 2008 | 08:35 AM
hokiruu's Avatar
I am just kind of **** about stuff like that and prefer to keep things as simple, separate, and direct as possible. When you have multiple vacuum sources hooked up to each other, if the primary one comes loose, multiple things can be affected. but that's just me, to each their own.
Old Aug 11, 2008 | 09:30 AM
gsrboi80's Avatar
Agreed . Wish Buschur made that nipple on thier Turbo outlet pipe
YogSaahoth
Nov 10, 2016 02:49 PM
tscompusa
Nov 14, 2012 03:13 PM
YogSaahoth
Jan 18, 2010 05:15 PM
YogSaahoth
15
Aug 20, 2009 08:44 AM
YogSaahoth
15
Jun 23, 2007 09:23 AM
