best plugs for fp green/alchy
Old Aug 17, 2008 | 04:19 PM
afmafia's Avatar
hi im running an fp green with an aquamist alky kit what the best plugs to run . right now im running ngk br7es gapped to 26 . ? thanks in advance for the feed back
Old Aug 17, 2008 | 04:21 PM
Warrtalon's Avatar
BR8ES gapped as high as you can get away with, but I wouldn't expect more than .024...maybe only .022.
Old Aug 17, 2008 | 04:24 PM
SuPeRNeT's Avatar
Yep bre8es are where it at!!!
Old Aug 18, 2008 | 07:32 AM
afmafia's Avatar
isnt an br8es to hot of a plug
Old Aug 18, 2008 | 08:03 AM
Warrtalon's Avatar
It's not as hot as the 7s you use. 7s are stock heat range, and 8s are one step colder. I hate to say it, but you could have easily learned this by searching. There is a newbie forum for newbie questions in the future - just trying to help.
Old Aug 18, 2008 | 08:36 AM
Soon2BEVO's Avatar
I used BR8ES gapped to .024 with success. If you gap them a little lower you will get a little more life out of them though. But for $8 who cares :-)
Old Aug 23, 2008 | 05:58 AM
afmafia's Avatar
how are the br8eix
Old Aug 23, 2008 | 09:45 AM
Warrtalon's Avatar
They are the same but Iridium - not designed for high boost and cost a lot more but will last a lot longer, too. We use the S style, because they are copper and less than $2/pc.
Old Aug 23, 2008 | 06:50 PM
afmafia's Avatar
i thought the br8eix are for high boost
Old Aug 23, 2008 | 08:29 PM
Warrtalon's Avatar
IX = Iridium
8 = one range colder
We use copper for high boost typically.
Old Aug 24, 2008 | 04:37 AM
afmafia's Avatar
wartalon i switch out my coils and plugs the code has popped up yet
Old Aug 24, 2008 | 06:57 AM
scheides's Avatar
EvoM Moderator
BPR8ES gapped to .023" here, 29psi peak no problemo.
Unless you have an IX, just run the copper plugs and change them every 6 months or if you have some sort of incident that would foul the plugs really bad.
Old Aug 24, 2008 | 07:43 AM
dsmfan95's Avatar
I always use BPR8ES gapped to around .022"-.024".
Old Aug 24, 2008 | 09:30 AM
Warrtalon's Avatar
It HAS or HAS NOT?
Yeah, I wanted you to do that quick swap just as a cheap/easy test.
Old Aug 24, 2008 | 09:52 AM
Fastlaser92's Avatar
im running BPR8ES without problems
