HELP! something went BOOM
Old Aug 19, 2008 | 05:36 AM
DBallz's Avatar
From: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
Yeah when you run at the track from a dig your supposed to slip the clutch. Also if you not running headsup you shouldn't worry about ur r/t. You can sleep at the green for 5sec if you want. Were u able to drive the car home?
Old Aug 19, 2008 | 06:24 AM
jmelocik's Avatar
Put it in gear and let it idle and get under the car and see if the driveshaft is spinning, if it's not then you know it's not the rear end. That pretty much narrows it down to the T case since the tranny is spinning and the rear end isn't. Just my redneck trouble shooting! LOL
Josh
Old Aug 19, 2008 | 10:23 AM
Wicked E's Avatar
Josh
Great advice!!
So what happens if its NOT the TC and the car ends up rolling with you under it?
I guess Rednecks really do think of the consequences of their actions...
-E
Old Aug 19, 2008 | 11:05 AM
speedfreak0920's Avatar
so t-case. great. ha no i couldnt drive my car home. i had to pay 300 bux to tow it from wisconsin to my house. doesn't shepperd do a rebuild ? how much is that? thnx for everyones help. its going up on jack stands 2night so i'll find out more info. and let you guys know. thnx again. ill keep every1 posted
Old Aug 19, 2008 | 11:09 AM
AudiA4_20T's Avatar
I know I dont have an evo but the same thing applies to my Audi with my AWD. When you snap an axle, the AWD sends the power to the least resistant wheel which obviously isnt doing anything without an axle. The car will run fine and the speedometer will even tell you the car is moving but its not.
I know the transfer cases go more on the Evos though so if everyone else seems to think thats it, Id put my money on it
EDIT: just saw you said the axles look fine, wouldnt hurt to check again tho
Old Aug 19, 2008 | 11:54 AM
jbrown's Avatar
ShepTrans does a rebuild, but if you have already shredded it, you can't fix it. Mitsu doesn't sell the ring and pinion separately, the only way to get them is to buy a whole new T-Case (@zzholes). I know because it happened to me.
Old Aug 19, 2008 | 12:01 PM
Warrtalon's Avatar
Shep buys up all the ring and pinion sets and can do rebuilds now...has for a while. You no longer have to buy a whole t-case. I just had mine rebuilt in the last 6 months - was nice and easy. However, he buys sets of 30 at a time and runs through them like hotcakes, so get on his list quickly.
Old Aug 19, 2008 | 01:09 PM
ny-quiL's Avatar
Originally Posted by Toxin
The 3k$ launch.
bwuahahha.
Old Aug 20, 2008 | 12:49 AM
john.schuber's Avatar
THAT SUCKS! This is why I will never ever drop my clutch. Hey look at the bright side, your going to get a bad *** shepherd transmission.
Old Aug 20, 2008 | 01:04 AM
sikrsix's Avatar
^^ Not if he is rebuilding his Transfer case.
Old Aug 20, 2008 | 10:30 PM
ok so talked to john shepard himself yesterday and told him everything that happened. we're pretty confident its my output shaft. he said if it was my tcase there would still be some kind of movement. so its more than likely the output shaft. since the labor is pretty much the same to do a full tranny rebuild, and id do that in the future anyway, i'm going to opt. for a full shepard tranny rebuild and run their new billet output shaft which is 300 bux more. so all in all it's going to be about a 1300 repair. but...with a shep tranny! car will be down for almost a month because of the busy schedule. maybe i'll take it to the track late this season and try some launches. i'll keep everyone posted. and thnx again for all the responses
Old Aug 20, 2008 | 10:36 PM
tripperfx3's Avatar
Looks like everything worked out in the end . At least your getting a near bulletproof trans and your not spending 3k.
Old Aug 21, 2008 | 01:27 AM
Ride927's Avatar
rember when you make one part on the car stronger other parts become weaker..
slip then dump...
clutches are a lot cheaper then trannys
Old Aug 21, 2008 | 06:00 PM
justa4banger's Avatar
just wat i thought too
Old Aug 21, 2008 | 06:47 PM
pls1968's Avatar
The last time I heard a boom this is what happened.
