Evo IX cams: Kelford 272 vs. Cosworth M2
Old Aug 23, 2008 | 09:46 PM
hytek369's Avatar
Originally Posted by joedr
If you go to anything like M2s or higher... I would wait another 2-3 months (since you already waited that long for the FP4s) and buy some decent springs and retainers.
I am very impressed with the S2s so far! If you are going to stay with small turbo, then go with the S1s.... no need to upgrade the valvetrain.
My car ran the M2s, S1s and S2s! S2s are winning IMHO.
i waiting for someone with experience from both M2 and S2.
Old Aug 23, 2008 | 10:08 PM
o-townFLA's Avatar
I gained 28hp at 6700rpm with the cossies, tuned to 21psi on 91 octane. And this was after I had already had a tune from a month prior...
check it: https://www.evolutionm.net/forums/sh...=cosworth+cams
Old Aug 24, 2008 | 05:40 PM
Kracka's Avatar
Well, I ended up finding a set of used FP4R's with 2k miles on them and my buddy is going with the Kelfords.
Old Sep 1, 2008 | 09:55 AM
ecuflasher's Avatar
Originally Posted by ecuflasher
Since the 2 offer similar performance, how should we choose between them? Which one has the better quality? I'm looking to downsize from my M3s to something that can give me more midrange torque and faster spoolup.
Bump for reply from TTP
Old Sep 1, 2008 | 10:19 AM
EE's Avatar
EE
You can't go wrong with the S2's
Old Sep 1, 2008 | 04:44 PM
TTP Engineering's Avatar
The Kelford 272's are specifically designed for GT35R or larger turbos.
Kelford has more experience making cams than many "manufacturers" combined. They literally have a grind for every application.
Old Sep 2, 2008 | 12:25 AM
peteformance's Avatar
I am waitng to see what the kelford cams can do compared to the cosworth cams..They both have the same stats but what do they do on the road and dyno..A way to test this is for someone to put on first on set go to dyno and see what it does on the road then put the other set on to see what it does..But who would do that..Me of course I would not do that..I am building my motor and now i just bought valves retainers BC and i bought Kelford cams 272...I am fixing my motor 2.3 and i will tell you guys what i see from these cams...To be honest I am going to say they rock because I have not tried the other cams..And if i go and race someone with cosworth cams he cant have the same car like me..He might be a better driver might have racing fuel without me knowing it is tough to judge cams I think...Thats my 2cents...I hope this helps but when i dyno it i will post it ...
Old Oct 7, 2008 | 08:12 AM
Kracka's Avatar
My impressions after a month:
I am less than impressed with my Forced Performance FP4R cams. They idle much rougher and made less peak whp/wtq than my friend's car with the Kelford 272's. My car did hold power better near redline though. We have nearly identical setups with the stock IX turbo. We were tuned on the same day by the same tuner on the same dyno. I've spent the past month trying to get my idle dialed in correctly when it took us less than an hour on my friends car. I think I'm finally almost there but this was still just too much effort; especially considering the lack of gains. We were both heat-soaking our stock FMIC's so I'm hoping more gains are to be had once I upgrade that. If I had to do it again I'd probably just stick with the stock cams, or if I did buy a set, it would be the Kelfords. With their idle, spool, and low throttle drivability characteristics I see no reason to go any smaller than the Kelford 272's on the IX.
Old Oct 7, 2008 | 08:22 AM
DeiPro's Avatar
If I had to choose between Cosworth and Kelford, I would honestly choose the cheaper cam. Other than price, you will not find much differece.
Old Oct 7, 2008 | 09:20 AM
The FP4R take an irregular mivec mapping to get to run correctly. We worked out the details on the dyno with these. Definately takes a lot of experimenting to get them right.
Old Oct 7, 2008 | 11:36 AM
Kracka's Avatar
Yeah, my MIVEC map looks a whole lot different than the one used with the Kelfords. You should send me the one you created so I can compare
Old Nov 25, 2008 | 09:11 PM
TurboRSX04's Avatar
bump for anyone who has either cams
Old Nov 27, 2008 | 03:58 PM
meltdown's Avatar
S2kracka- can your friend share his dyno graph with the Kelfords? I'm interested in them myself although TTP's response makes me think they might be more than I want since I'm also on the stock turbo.
Old Nov 27, 2008 | 04:08 PM
o-townFLA's Avatar
heres my Cossie graph...
tuned on 91 octane at 21psi
Old Nov 27, 2008 | 04:13 PM
TurboRSX04's Avatar
nice, imagine on some race gas i bet u will make alot more torque.
