Witch size block for hta37
Old Aug 23, 2008 | 06:37 PM
dsm25psi's Avatar
I got an 88hta turbo coming and wanted to get some opinion on what size block i should run. Should i do 2.0 and rev high or stroker. I was thinking of using the 2.4 block and building that. What would be the best for this turbo?
Old Aug 23, 2008 | 06:47 PM
SpunEvoIX's Avatar
i would say 2.0 so you can rev it high
Old Aug 23, 2008 | 07:02 PM
AWD Motorsports's Avatar
2.0L and rev it.. fp88 and 2.0L has been Proven to run 8's already.. You cant go wrong!!
Old Aug 23, 2008 | 07:15 PM
1d10t's Avatar
2.1
rev really high
Old Aug 23, 2008 | 07:22 PM
DS-03evo's Avatar
You will want a 2.0 for the revs, or maybe a AMS 2.3RR.
Old Aug 23, 2008 | 07:46 PM
dsm25psi's Avatar
true that
Old Aug 23, 2008 | 07:50 PM
SpunEvoIX's Avatar
i went 2.2 magnus stroker for my gt40 and rev to 9,000
Old Aug 23, 2008 | 07:51 PM
dsm25psi's Avatar
wow rev 9 with a 2.2 nice
Old Aug 23, 2008 | 08:14 PM
justboosted02's Avatar
destroked 4g64 i.e, 2.1 or 2.2
Old Aug 23, 2008 | 08:27 PM
DynoFlash's Avatar
I personally like 2.0 L the best
Lately I have tuned a few 2.1 and found them to be very similar to the 2.0
I personally hate 2.3 and 2.4 engines as they loose way too much power over 8,000 when a race motor really starts to take off
At the end of the day you need to review what kind of driving you are considering and then pick an engine which is compatable with your intended style of driving
E.g. and auto cross racer would prefer a stroker 2.3 to get low end tq while a drag racer is better off with a 2.0 all day.
Al
Old Aug 23, 2008 | 08:39 PM
SickSilverNLow's Avatar
Built 2.0 liter is the best.
Old Aug 23, 2008 | 08:43 PM
DeiPro's Avatar
Al
Stroker motors only "loose too much power over 8,000" due to the head ports and intake valve sizing being engineered for the bore and stroke of a factory engine. If you put a head designed for a 100mm stroke 2.3L engine with cams that are appropriate, there will be "no loss of power". It is either this, or the turbo you have used in making this statement was simply too small, but I would assume the first applies.
If the 2.3L bottom end geometry does not allow one to rev and engine to the RPM to spool the turbo, or get enough working RPM out of it, that is a completely different story.
Personally I am a fan of the 4G63 2.3L, yes there are better combinations that will yeild an engine that will spin higher with less stress, but it is a rather simple and effective engine combination. The problem is that no one has really developed an appropriate head for this bottom end geometry. But that dosent mean there isnt one in the works on my end
Old Aug 23, 2008 | 09:07 PM
DS-03evo's Avatar
Hmmm
Old Aug 24, 2008 | 12:21 PM
dsm25psi's Avatar
what will the spool be with the 2.0?
Old Aug 24, 2008 | 12:29 PM
EvoDan2004's Avatar
you cant really compare a drag evo that weighs nothing like a street car that runs 8s to a street car not dragged out... not right if you ask me.. although that was a nice pass.
