Perrin high flow cat - Don't waste your money
Just what the title says. I had mine on for a year. Its a POS. I was running a little rich, but not too bad and I look back through my logs and after just a few short months of using it it was nothing but an exhaust restriction. After about 6 months I started getting exhaust leaks elsewhere due to the backpressure. It made the car run sub par and I thank Mellon for helping me find the problem.
I took it off last night and youc an't even see any light through the honeycome and the honey come has come loose and is laying almost sideways creating a great restriction. Its started falling apart and this is only after a year, I imagine its been like this for 6 months. If your really really set on a HF Cat spend the money and get a good one and pull a log every month or so and see if your airflow is dropping off.
Thats just my P.S.A. for today. I had good reason to run it last year but I am beyond that now and I won't ever make that mistake again.
My only point is, if you need/want an HFC for whatever reason stay away from this one or keep an eye on it cause it won't last period. Its a whole lot of money for an exhaust restriction thats gonna stop working in 6 months.
Some times for the extra power you need to put up wit the SES light.
Im sure more than half the modified evo's on here are running with a SES light, all you do is check the code, make sure its the o2 sensor and live with it.
Wow! So it took 25,000 miles for the light to come back on? Well what I did was double up on the fowlers....took a little drilling but I haven't had trouble since. Ill make sure to look out for that code to come back on then.
