Ive searched and searched but nothing....does anyone know the stock gauge size on the sport meter kit?...like in mm's
thanks in advance guys
IIRC, they're 44mm, but I'm not 100% sure. Try searching for a stock boost gauge replacement.Originally Posted by 06_RALLI///ART
Ive searched and searched but nothing....does anyone know the stock gauge size on the sport meter kit?...like in mm'sthanks in advance guys
pretty sure they're 48mm. omori makes gauges that are IIRC just as small if you're thinking about a direct swap.
yeah thats what im looking into is a direct swap....I have the sport meter kit on its way but I want to replace them and use the single din mount for my new ones....
so its either 44mm or 48mm?
Quote:
Looks like we're both slightly off. The Omori gauge is 45mm and the stock gauge is ~42.5mm, so the stock gauge opening needs to be expanded just a bit to fit the Omori.Originally Posted by holler mcdollar
Dude, if you're looking at putting different gauges in that location, you need to rock this (takes 52mm guages - plentiful and less expensive)
http://www.42draftdesigns.com/catego...ts/tgp_evo.htm
