manual boost controller vs profec b II
Old Sep 3, 2008 | 04:07 PM
Gary@MellonRacing's Avatar
Talking manual boost controller vs profec b II
does any one know which is better for an evo 8 on ecu flash on a green turbo , pump and vp , i want to know which one i should go with i have both i just want to know which is better and why ????
Old Sep 3, 2008 | 04:16 PM
PeteyTurbo's Avatar
When running high boost on the profec I wa running into big problems trying to get every last bit out of the stock turbo, would rally only allow 25psi peak when banging through the gears or else it would fluctuate horribly if I turned it up more.I tried everything but the jdm BOV leaking a bit may have had something to do with it. Switched to a MBC now and spoolup is definitely better with none of the profec fighting to try and slow the boost when it gets near the desired level..I tried EVERYTHING on the profec to eliminate the issues..Worked decent on a 3rd or 4th gear pull but at the track it was a hinderance.
Old Sep 3, 2008 | 04:18 PM
Mellon Racing's Avatar
I had a MBC I made out of parts from home depot years ago and used on several of my turbo cars. I bought the greddy profec B spec II and the boost response/hold was exactly the same.
Old Sep 3, 2008 | 04:40 PM
fostytou's Avatar
EvoM Community Team
or you could try ECU boost control with a GM 3 port
Old Sep 4, 2008 | 03:44 PM
ecu boost control with a gm 3 port ??????? can u explain how this works???
old G
14
Mar 29, 2012 12:41 PM
LhanaPong
10
Aug 5, 2011 01:37 PM
carlosdevil10
Lancer Aftermarket Forced Induction Tech
16
Feb 17, 2010 12:02 AM
Blue Evo 8
13
Mar 8, 2006 03:55 PM
blacklancer03
10
Dec 18, 2004 01:37 PM
