Compression Numbers.
Old Sep 3, 2008 | 07:53 PM
blueprint's Avatar
Just checked my compression and here are the results.
#1: 150
#2: 145
#3: 135
#4: 145
Does this indicate a healthy motor or a motor on it's way out?
Old Sep 3, 2008 | 08:08 PM
YzBrad99's Avatar
DID you use a digital tool or a analog? Was the engine still warm? Did you hold the throttle fully open during each revolution?
Old Sep 3, 2008 | 09:11 PM
blueprint's Avatar
sorry i should've elaborated a bit more.
i used an analog tool and the engine was warm. the throttle was full when i cranked it over to get the readings.
car is a 05 Evo MR with 77k miles.
Old Sep 3, 2008 | 09:33 PM
Evo8luva's Avatar
With MY analog tester on my evo8, when it was stock motor, it would blow 180 +- 10psi and by buddies evo8mr would blow 170-180psi and another buddies blew 165-175 on his 05 evo8 with a different tester. Take it for what its worth.
Old Sep 3, 2008 | 09:37 PM
bluebanana23's Avatar
mine was from an analog which came out with mid 170's. 03' with 42K.
Old Sep 3, 2008 | 10:22 PM
justboosted02's Avatar
absolute compression numbers are only part of the story, you should be more concerned with variations between cylinders.
you have a variation of 10% between your lowest and highest cylinder, which is the max variation that is still considered ok. i would keep an eye on it and start doing compression tests whenever you do an oil change
Old Sep 4, 2008 | 07:37 AM
jmartinez1170's Avatar
^ yep
if i were you i would be looking into it as well. Could be alot of things over time injectors dont spray what they should carbon buildup and so on. Tune is a factor. If your on stock ecu you will be fine wuth theses numbers if the ecu see's anything out of the norm it will go into safe mode. my # 4 piston was down to 75 for almost a year didnt notice it untill we put the AEM in the car. Before that i knew there was a problem as i would lose tp other evos with less mods. After the aem was in a week later pop as it wouldnt go into safe mode.
Old Sep 4, 2008 | 07:46 AM
C6C6CH3vo's Avatar
Depends on if those #s haven't changed since the car was new.
My compression has had an 9 psi (5%) difference since day 1 60K miles ago
ShanesEVO
39
Apr 2, 2022 09:43 AM
Runker
Apr 26, 2016 05:23 PM
jax408
13
Feb 17, 2015 11:48 PM
dsmchiz
Aug 26, 2014 07:54 AM
vinnieg
18
May 8, 2012 01:48 PM
