FP Red, E85, 454hp/408tq @ 26psi
Hopefully they will figure out the problem. I hope I have got everything to not run into these issues when they tune my car.
Im glad we noticed that on the sheet so you could let tyler, and the rest of those guys look at it.
its Rob by the way
its Rob by the way
Just my 0.02! I second the look for the boost control setup. Either the WGA is messed up or you have problems with the hallman.
1. Good test would be to swap MBC with a known good one. It is easier to check that an MBC is running well than the WGA.
2. For the amount of boost you are running, I would go 2-3 full turns on the adjustable WGA after finding the normal position. The position where the little hole on the WGA leg hardly enters on the flapper. There was a video on FP website showing how to adjust the pre-load.
I personally have not seen a red performing (boost wise) but 5200 for 20 PSI seems to be a bit higher in RPMs.
Definitely, look in there and you will find a more responsive car.
I think your dyno will read the same because I was told that because of the use of a 10' line the dyno boost plotting is delayed... Mark has posted his dyno was off by about 2000 rpm for showing his Actual peak boost...so if that's the case I'd be peak boost at about 4600 RPM, which would be spot on for this altitude.
Thank you
My logs from the JDM map are not that far either from the dyno sensor that is about 10' away as well.
In defense of the delayed boost logging, before I starting dissecting the dyno graph I did mention on the ride home to my buddy that the boost comes on crazy quick and doesn't seem to match the dyno graph... I still think it would be worth my time to have things fully checked.
The boost is always delayed on this dyno.. For whatever reason it just it.. Once you get the AEM you will be able to post your log and then it will show when the real spool up is.. Don't sweat it if the car feels good then its probably fine..
But based on personally experience on that dyno the boost readings are very delayed..
Congrats on the build by the way i saw it at the track, it turned out very nice!!!
Everytime i have dynoed there the correction factor has always been around 1.222 or so and when i hit 635AWHP corrected it netted me about 134MPH trap..
Mark
Mark
Thank you much and I had found your post before in reference to that dyno being delayed on logging boost.
