help please breaking up in boost
Old Sep 12, 2008 | 02:48 PM
03evoslowtion's Avatar
Angry help please breaking up in boost
i arched my battery when taking intercooler pipes off to run hard pipes after i was done installing, my car started to only break up in boost.... changed out my aprk plugs today
does anyone have any idea no engine light, scanned it and no codes were shown
runs fine untill it hits 2 psi
255 walboro
3" buschur exhaust
hard pipe intake
hard pipe intercooler kit
br7 ngk copper plugs
hallman manual controller
Old Sep 12, 2008 | 02:56 PM
RoadSpike's Avatar
Are your plugs gaped correctly? Just changing out the plugs does not guarantee proper gaping.
Old Sep 12, 2008 | 02:57 PM
there gapped right but its doing the same exact thing as it was before
Old Sep 12, 2008 | 02:58 PM
markymark1082's Avatar
The new pipes could have allowed more air which could cause you to run more lean. Just a thought.
Old Sep 12, 2008 | 02:59 PM
i have a wideband its at 10.7 when it breaks up
Old Sep 12, 2008 | 03:04 PM
what are the plugs gapped to?
Old Sep 12, 2008 | 03:06 PM
26
Old Sep 12, 2008 | 03:08 PM
its probabley something real dumb... i mean no codes no light... so i might have a weak wire or coil thats my next check but maybe some1 had this problem and knows exactly what it is before i go buyin random s***
Old Sep 12, 2008 | 03:09 PM
also my idle after it does break up if i throw it in neutral is goes really low and back up again
Old Sep 12, 2008 | 03:11 PM
that sounds like a boost/vacuum leak. check all you couplers on your piping again.
Old Sep 12, 2008 | 03:12 PM
check your bov too.
Old Sep 12, 2008 | 09:55 PM
fixed the problem the battery was holdin the couple on the throttle body but,if u pulled up on the pipe it jus slide right off so that fixed the problem the only thing is my cars idle like to drop a little bit
