Autometer Colbolt boost gauge problem
Old Aug 28, 2003 | 05:17 PM
Ryanmcd2's Avatar
In Timeout
Well I installed the gauge it worked perfect until I turned the car off. The I started it up after filling with gas and it reads like 12 pounds and then goes to 30????? I turned the car off and on a few other times and it's still screwed. I know I read about this before but I could not find out what to do to fix it.
Thanks again
Old Aug 28, 2003 | 05:31 PM
nastea's Avatar
hrmm
what line did you tap?
Old Aug 28, 2003 | 06:48 PM
Ryanmcd2's Avatar
In Timeout
The wrong one. Now I need to know how to get it 0ed out again. I will tap the other line tomorrow.
Originally posted by apursell
hrmm
Old Aug 29, 2003 | 11:17 AM
3K's Avatar
3K
Ryanmcd2
Which +12v wire (red wire) did you tap into? In the instructions it say's that you need to tap into a 12v source that doesn't break connection during start up. Otherwise your gauge will auto compensate with the wrong calculations and give misreadings.
I also have the cobalt gauge but haven't installed it yet. Waiting for my gauge holder to arrive. Anyhow I would like to know which wires you used to tap into, and if you wouldn't mind sharing this info? Also if you have pics. Greatly appreciated. Thanks eric
Old Aug 29, 2003 | 11:25 AM
HobieKopek's Avatar
Does the Evo come with a little distributor block on the positive terminal like the Lancer? I dunno what most of you guys are doing, but I ran a new 12v line off the distributor for my future LED project. Right now it's powering my EGT.
