Removing t-case ?
Old Sep 17, 2008 | 04:57 PM
eyebrowski's Avatar
Removing t-case ?
Posting from my blackberry...
I have the t-case seperated about an inch from tranny and I can't get it any further. I'm shaking the hell out of it... Any suggestions?
Do I need to take the front subframe off?
Old Sep 17, 2008 | 05:51 PM
Bimmubishi's Avatar
I'll PM you with what I think the problem is.
Old Sep 17, 2008 | 06:00 PM
Duh Panda's Avatar
make sure all bolts are off ... the 6 main bolts... if they are all lose just try and rock the t case up and then and use a pry bar
ive never had an issue removing the tcase
Old Sep 17, 2008 | 06:19 PM
eyebrowski's Avatar
Yeah, I need to remove the input shaft. The slide hammer I picked up isn't m8x1.25 so I need to whip up an adapter tomorrow. Thanks for the help.
Old Sep 17, 2008 | 06:36 PM
RoadSpike's Avatar
if you have a slide hammer just pick up a bolt that fits and use the claw attachment to yank on it with the slide hammer.
Old Sep 18, 2008 | 07:49 AM
EricLoveYouMost's Avatar
slide hammer ftw.. i had the same prob when i did min lol.. once u pull that shaft out you can bang thru the other side and itll fall right out
Old Sep 18, 2008 | 07:59 AM
Celica2EVO's Avatar
Once the input shaft is out the TC will come off. You dont have to take the subframe off, but it does help to loosen it and lower the front down and inch or 2. And use the adaptor that looks like 2 squares and put a bolt that fits in there and it will come out.
Doctro X
Dec 10, 2016 10:35 AM
Blue91lx
May 23, 2012 06:05 PM
stuntman213
Mar 6, 2010 08:49 AM
lillev23
Jan 12, 2010 11:49 AM
TeamValorRacing
10
Mar 21, 2009 09:22 PM
