NEED HELP tcase problems
Old Sep 22, 2008 | 03:25 PM
mullen's Avatar
ok so here's the story, last month i got my trans rebuilt by buschur put it back in and then i lost my pass side tcase seal. or so i thought, i then replaced it and now im getting the same problem as i had before. my tcase shoots the fluid out that seal but only at highway speeds? ive been driving it daily since the seal was replaced and not a drop has leaked...i lost half my fluid both times, both only cruising at highway speeds, not any louder than before, not vibrating or anything...no signs of wear the only thing i can think of is when i was putting the output shafts back in when i put the trans in i mixed the two sides up and realized it when i couldnt get it to set properly. so my question is do you think i might have shifted something on the inside or perhaps ruined the inner seal? thanks
Old Sep 23, 2008 | 12:18 PM
mullen's Avatar
so im thinkin its the vent on it...read that it might cause the fluid to spray out at higher speeds
