FP Red and BR lower IC pipe fitment
Old Sep 24, 2008 | 09:41 PM
wkehn's Avatar
Anyone have an issue with the red turbo and the BR lower IC pipe (the one meant for the race core) in that it is dangerously close to the starter wire power lug? I tried bending the little tab that surrounds the lug and got about 1/8 inch clearance but on hard pulls the motor rocks and it shorts against the pipe. Rotating the compressor didn't seem like an option either with the solid feed line. Robert, is there a pin that mates the 2 turbo halves together?
I could probably shave a little more off the tab but wanted to see if this was common before doing so. Dave, what do you guys do about this?
Thanks
Old Sep 25, 2008 | 07:26 AM
ForcedPerformance's Avatar
You need a EVO9 compressor outlet pipe. Do not use the EVO8 pipe on the EVO9 turbo, you will start a fire.
Old Sep 25, 2008 | 07:27 AM
Do not attempt to change the rotation or orientation of the housings on a EVO8 or EVO9 turbo.
Old Sep 25, 2008 | 08:07 AM
wkehn's Avatar
Thanks!
David Buschur
Sep 18, 2015 02:21 PM
SLVRNBLK
28
Apr 24, 2014 01:08 PM
Dynotech Tuning
Aug 12, 2013 06:10 AM
dinok
11
Jan 13, 2010 07:41 PM
evo_8_u
Midwest Region
May 9, 2008 11:04 AM
