Intercooler End Tank Design/Theory
Old Nov 1, 2008 | 05:58 PM
evokel's Avatar
i think CBRD did something like this.
Old Nov 1, 2008 | 06:17 PM
vicksen's Avatar
Thank you for this write up and also the link. This helped me in my choice of intercoolers.
Old Nov 2, 2008 | 06:34 AM
CBRD's Avatar
there is alot of consideration into end tank design etc...
some believe its negligible.... but when racing... every little detail counts..
attack with a razor not a sledgehammer in racing...
cb
Old Nov 2, 2008 | 07:17 AM
CaliMR's Avatar
Originally Posted by icantdrive75
Makes you wonder why OEMs aren't doing it.
Just something off the top of my head, but if the TB is before the IC and the pipes blow off (seems to happen a lot on Evos), then you would have no control over the flow of air into the engine? You should probably turn off the engine if you lose a IC pipe, but the average guy on the street might not know that and may try to drive it home or something and if they got hurt then that is just asking for liability issues = $$$
Also, OEM is all about what is the cheapest way to produce. I am expecting them to go to plastic end tanks like on modern radiators eventually
Plus they would have to redesign the packaging in the engine compartment, which is just more $$$
Old Nov 5, 2008 | 09:39 PM
icantdrive75's Avatar
Ahaha I didn't even think about that. I'm sure the MAF sensor dumping fuel into the chambers would keep the engine from getting out of hand, but it's an interesting proposition. I wouldn't mind seeing it happen to someone elses car :-D
Old Nov 5, 2008 | 09:42 PM
scorke's Avatar
http://www.are.com.au/feat/techtalk/intecoolersMR.htm
End thread.
Scorke
scorke's Avatar
cb
You might want to start making your own IC's then
Scorke
Old Nov 6, 2008 | 06:39 AM
CBRD's Avatar
Scorke
stranger things have happened
cb
Old Nov 6, 2008 | 07:57 AM
gsrboi80's Avatar
Old Nov 12, 2008 | 01:09 PM
03whitegsr's Avatar
Originally Posted by Aby@MIL.SPEC
the reason for the tb or inlet guide vanes aka IGV, was so when the throttle was closed on the engine, the igv also closed, so the turbo couldnt take in any air, allowing the turbo to free-wheel & minimize the ability for the turbo to slow down.....
with no igv, the turbo would take in air, loading up the area between the closed engine tb & compressor wheel of the turbo. when this area gets filled up, the turbo slows way down because there is no energy driving the exhaust side of the turbo with closed throttle blades = turbo lag.
igv, isv, etc. were also used in CART by Cosworth & Honda.
Just one small detail that is kind of important. All of those cars also used individual throttle bodies in the intake manifold. Thus the actual engine response is controlled by the ITBs and these additional valves are likely controlled by manifold pressure and throttle position in an attempt to optimize turbo efficiency, provide a linear torque curve and to keep the turbo freewheeling in a lower pressure environment.
Old Nov 13, 2008 | 01:17 AM
cpoevo's Avatar
Aby definitely knows what he is talking about, he used to work on those cars.
Old Nov 13, 2008 | 05:21 PM
JKav's Avatar
Some engine manufacturers used IGVs to impart a 'pre-swirl' to the airflow just upstream of the compressor wheel. Using the IGV in this 'analog' manner reduced the incidence angle of the flow at the inducer, improving compressor efficiency during part-load operation.
Others just snapped the IGVs closed to reduce compressor load during gearchanges (as Aby mentions). This sends the compressor into deep surge momentarily so a robust bearing system was a must when IGVs were used this way...
Old Nov 15, 2008 | 09:30 PM
rawkus's Avatar
Awesome, appreciate it.
Dan
Old Nov 24, 2008 | 08:57 PM
Steveevo9's Avatar
Dan
Just about added this link for you as well, lucky I read the whole thread. It's a very interesting read from ARE, that's their gig....cooling.
Steve
Old Nov 30, 2008 | 11:07 AM
Yhperformance's Avatar
wow!!!
