help plz
Old Sep 28, 2008 | 04:56 PM
evo8nfs's Avatar
help plz
does ne one know what these parts are??? and if they have them that i could steal off a blown or spare block??
Old Sep 28, 2008 | 05:02 PM
crewdawg130's Avatar
What parts do you need. Are you talking about the water pump, timing belt pulleys, tensioner, crank position sensor, trigger wheel, oil pump.....dude is alot. a lill specific?
Old Sep 28, 2008 | 05:07 PM
rcheung's Avatar
Those red circles are very faint and if I didn't have a keen eye I wouldn't even notice it since you did t not specify it in your post.
Old Sep 28, 2008 | 05:12 PM
GOOD EYE BRO!
Thats your Crank Positioning Sensor "trigger wheel". get it from your dealer cause is cheap..
Old Sep 28, 2008 | 05:15 PM
evo8nfs's Avatar
sorry for not being specific... i have the trigger wheel.. but what i need are the peices that stick on the trigger wheel.... any ideas what those are??? like rc had said they are circled in red. Thanks for the help guys!
Old Sep 28, 2008 | 05:22 PM
That IS the trigger wheel. post a pick of what you're calling a trigger wheel. There is only 3 things bolted to the front of the crank. the timing belt drive gear, behind it is the cps trigger wheel and then the rear balance shaft drive gear.
Old Sep 28, 2008 | 05:26 PM
i think what your are seenig is the tooths of the trigger wheel scuffed by the timing belt.
Old Sep 28, 2008 | 05:34 PM
evo8nfs's Avatar
ok if thats the case.. well im throwing a code for the Cps. ive replaced the sensor and i sill have the code... any ideas of what the issue could be?
Old Sep 28, 2008 | 05:48 PM
does the car run? or wont even start
Old Sep 28, 2008 | 05:56 PM
evo8nfs's Avatar
wont start.. no fuel no spark and the cps is the only code thrown.. ive checked plugs, wires, fuel pump, fuel lines, pretty much everything i could think of...
Old Sep 28, 2008 | 05:58 PM
is def the cps again...did you buy it new? did you change th etrigger also or just the sensor
Old Sep 28, 2008 | 06:00 PM
evo8nfs's Avatar
yea i replaced both... brand new... it was a real pita...... im soooo confused on what else it could be...
Old Sep 28, 2008 | 06:08 PM
no gas/ no spark...cps again bud. you gonna have to check the install on that thing. inspect the sensor
Old Sep 28, 2008 | 06:10 PM
evo8nfs's Avatar
yeah i'll have to check it yet again.. thanks for your help!!!
