NOS Anyone?
Old Sep 29, 2008 | 08:45 AM
500hpOnPumpEvo's Avatar
NOS Anyone?
Anyone using NOS on a window switch to help spool?
Whats your setup and config?
Thanks,.
Old Sep 29, 2008 | 09:46 AM
EvoIXJDM's Avatar
I usually use nitrous, with a zex kit and a zex window switch, with no problem, 75 hp shot and 25 psi, tuned by Jestr.
Old Sep 29, 2008 | 11:31 AM
Sweet, what do you have your "window" set to?
Old Sep 29, 2008 | 02:04 PM
EvoIXJDM's Avatar
Its set 3.5 start and 7.5 end.
Also set to 1 to start at 2nd speed.
Old Sep 29, 2008 | 03:16 PM
Old Sep 29, 2008 | 03:30 PM
EvoIXJDM's Avatar
The Zex windows switch, has a function that allows you to set the shift when it activates the nitrous, so I put 1, to activate it when I hit the limit rpm (7.5), so Its activate in the the second speed.
Do you don't want to activates it at WOT on the start line, lol
Old Sep 29, 2008 | 03:38 PM
The Zex windows switch, have a function that allow you to set the shift when it a activates the nitrous, so I put 1, to activate it when I hit the limit rpm (7.5), so Its activate in the the second speed.
ahhh Now i get it!! thanks!
Old Oct 5, 2008 | 06:49 PM
Billy@EnglishRacing's Avatar
just make sure you have a good tuner and a failsafe
Old Oct 7, 2008 | 01:23 PM
Which wire do I use for tps signal for Zex?
